During the enduro at last week's SVRA Sebring event I lost oil pressure and though I shut down as soon as the light came on it was not quick enough to avoid burning up a couple of rod bearings and maybe worse. ( BTW this was in the sports racer which does not have an Accusump.)
During the long drive home I was thinking about plumbing a normally-closed oil pressure switch that would ground the coil in the event of oil pressure failure, with some kind of momentary switch to bypass it for starting, etc.
Taking the concept one step further I believe the pressure switch in the Accusump in my Courier has two circuits, one of which is normally open and is "made" by low OP which opens the valve to release the stored pressurized oil. I believe the other unused circuit is normally closed and perhaps it could be used to ground the coil and kill the engine at the same time as the Accusump valve opens.
I'm sure someone else must have had the same idea but has anyone done this?
