Lotus Blossom for America?
JBsC5
Malaysian-British Lotus Elise roadster brings basics back to the states
By MARK RECHTIN
A U.S. Elise, due in late 2003, won’t be quite the same: That distinctive nose won’t pass the safety standards, and the interior needs airbags, at least. Softer springs, leather and a/c will further sanitize it for your protection.
Today’s “sports cars” are so loaded with an alphabet soup of ABS, ESP and DSC that it is nearly impossible to make the car go FUBAR. Not so the Lotus Elise, which is raw and feral underfoot, in its element as a track car. It’s a purist’s delight.
For the United States, Lotus plans to add nice bits like air conditioning, leather seats and a CD player. Oh, and airbags—like in the Opel/Vauxhall Speedster version of the car. The four-cylinder engine from MG-Rover has never been EPA-certified, and the Elise is so low that getting it through federal crash tests is proving troublesome. The solution appears to be a redesign of the nose. Bringing the Elise over is not a matter of choice for the U.S. arm of the sports car maker. It needs the Elise to replace the Esprit, which will depart in mid-2003. Lotus Cars USA CEO Arnie Johnson said at this year’s Los Angeles auto show that a federalized Elise will be here by fall 2003. The American Elise will have a 120-hp low-emissions engine and sticker at $38,500, including “everything but a hardtop,” Johnson says.
The suspension will be a little softer here than in Europe, too, since Lotus has eyes on sales volume. It’s got a plant that can build 10,000 units that’s only doing half that right now. Lotus Cars USA expects to bring in 2000 Elises a year.
“We don’t want to just chase the 10 percent of the audience who are petrolheads,” says Gavan Kershaw, Lotus’ chief dynamics engineer. Maybe the British fellow, interviewed at HQ in Hethel, England, doesn’t understand how big 10 percent of the U.S. market is, or maybe he’s serious, but there’s no way the Elise is going to become anything but a car for that cadre of folks Americans call “gearheads.” We’re bound to be excited about it if the owners (Proton and Petronas, Malaysian companies) stick with the plan to bring the car here.
When the Elise is pressed hard, the driver can feel the muscle and sinew of the car. There is a physical sense of biting brakes, engaging gears, the slip and grip of tires. That sort of immediacy between man, machine and road means driving errors are swiftly punished—though rarely in a cruel fashion—but lessons regarding the laws of physics are also learned at a much faster rate.
The novice racer’s self-inflicted idiocy is forgiven a bit by understeer dialed into the suspension. Hit a hairpin corner too hot and the Elise pushes wide, though the Bridgestone Potenzas don’t feel like they are knuckling under. Snap the quick-ratio steering and let off the gas, and the back end pendulums gently around. Feed in throttle, counter steer, and you have some rather wiggy four-wheel drift getting you through the corner. You can do it all day, giggling like a third-grader with a water balloon launcher.
It is almost impossible for the engine to outdrive the suspension and brakes. Not to say the 1.8-liter Rover K-series powerplant is a wheezy old bag, but it is rough and agricultural. To most people, 120 horsepower in a sports car is something to scoff at. But with a dry weight of a svelte 1565 pounds riding on a tidy 90.5-inch wheelbase, 0 to 62 mph comes up in 5.7 seconds, and 0 to 100 mph in 17.2 seconds.
It’s all about power-to-weight, and carrying speed into and out of corners. It’s darty, squirty and quick. Fourth gear redlines at about 105 mph, midway down the half-mile straight at Lotus Cars’ test track in Hethel, under drying conditions. Fifth gear feels tall, and there wasn’t nearly enough straightaway to whip the car to its 125-mph top speed.
The chassis’ massive side sills evoke the feeling of a claw-foot bathtub, which the reclined seating position does little to deflect. The seats are sculpted and reinforced for hard cornering.
The Elise prefers to be caressed rather than caned, as demonstrated when Kershaw was instantly 10 seconds faster—not to mention much smoother—around the circuit. During a sound thrashing of the Elise, not once was there a hint of brake fade, and pedal feel was consistent and reassuring. Simply put, the brakes were phenomenal—not that there was much weight to bring to a halt—but still eye-bulgingly strong.
For the mad dash around the Lotus track, as well as a week-long review around London, I drove the basic 120-hp Elise. Lotus also makes a sport model with 135 hp, courtesy of polished ports and tuned exhaust, and a racing version with 190 hp—which has been offered in the States under the “for competition only” provisions of federal rules. Soon, in part because those same rules will make the Esprit V8 unadaptable for America, the Elise will be federalized.
It may be the perfect car in which to learn to race, but in everyday use it can be a pain in the butt. The seating position is so low that you’re looking up at scooters, for Pete’s sake. The immediacy of the suspension—so revered on the track— becomes busy and jolting on the commute. Inserting oneself into the Elise requires an inelegant torsion of the torso that would do a praying mantis proud. In our test vehicle, the rear window rattled and buzzed. A defective Clarion audio deck would illuminate but not function, then later went full-blast and could not be turned off. The luggage space is enough for a day-pack, but forget the quick run to the airport or grocery store. The pedals are tiny and wedged into a footwell better measured for the aforementioned third-grader.
As appropriate for a British roadster—even one built by a company owned by Malaysian interests—the roof leaked. At speed, a trickle would drop straight down from the A-pillar onto the driver’s knee. Worse was the pond in the driver’s seat after the Elise was parked in a rainstorm.
First gear was recalcitrant at a stoplight. For those with a freeway commute, the Elise gets squirrelly above 80 mph with any sort of side wind. Other notes: The mid- engined Elise suffers poor cooling in slow traffic, prompting a toasty interior. The noise level is nearly intolerable, requiring shouting to converse with a passenger. Though giving a digital readout, the fuel gauge was erratic, insisting we had used more than 1.5 gallons of gas in 10 easy miles. The headlamps gave meager support at night. And the Lotus emblem peeled off the gearshift onto my hand.
One reason to drive it on the street is the look of the car, substantially more posh than the $30,000 asking price. If there were a vehicular design of Marion Jones in the starting blocks ready to spring, it is the Elise. Driving down a well-heeled London street, I was confronted by a pack of 10-year-olds (eternally the key demographic). One succinctly shouted, “That car is ruthless.”
Quite.
Tiger
So the shift knob and ball joints will be the same as the UK Elise?
78Z
hmmm ... sounds like a luxo-Elise. Why do they seem to mess up some great Euro cars when they bring them to N/A. I wonder if I could get a Euro spec Elise into Canada...
jagxke46
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Tiger:
<hr></blockquote>
I drove an Elise last week, after I learned to fold my body in half to get inside, and found the driving experience to be the most fun I've ever had in any automobile (except sexual). I want to have one as my every day car so bad it hurts, but I know I won't be able to pay or even justify $38K
for US spec "softer" car. Oh well, I'sll have to be content with my E Jag, 51 MGB-TD, and Drifter cycle, but I'd trade them all for a hard edged Elise to drive every day. What a pure blast.
DrEntropy Bit of Historic Lotus News Lotus 0
D New Lotus Elise video on YouTube Lotus 1
M Lotus Europa Spiral Pins Lotus 9
S For Sale Lotus Elan Factory Workshop Manual on CD/ROM - Type 26 - 1963 - 1965 Other British Classifieds 0
P Lotus 7 Spotted 3
P For Sale 2005 Lotus Elise Other British Classifieds 2
H Lotus Super 7 series 2 Race car for sale Lotus 0
TomMull CHASSIS SHIPPING Lotus Elan Plus 2 Lotus 22
D Lotus Elan S4..Bodywork evaluation..Strip & Paint? Lotus 10
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
Lotus Club SoCal LCoSC - Supercar Sunday Lotus Marque Day Meet Lotus 0
G 1990ish Lotus Esprit Spotted 0
T Lotus Turbo Esprit Issue Lotus 6
Lotus Club SoCal Supercar Sunday Lotus Marque Day Lotus 2
P Lotus Elise...2005-6 Lotus 11
P Lotus Elan Spotted 3
Lotus Club SoCal Supercar Sunday Lotus Marque Day Meet, Drive, Lunch & Wash Lotus 3
Lotus Club SoCal Sage Lotus of West Covina Cars and Coffee, Feb 18th, 2017 Lotus 1
69MGC Early 60s Lotus Elite Lotus 7
Lotus Club SoCal 2nd Saturday Breakfast – Lotus Club of SoCal Activities Planning Meetings Lotus 0
kennypinkerton Lotus Esprit in alabama. Spotted 2
Nunyas Salvaged Lotus Evora rebuild video series Lotus 8
Lotus Club SoCal SoCal Lotus Club - Backyard BBQ Lotus 0
Lotus Club SoCal Supercar Sunday Lotus Marque Day Meet, Drive and Lunch Lotus 0
Lotus Club SoCal Lotus Club of So Cal Kick off Event & Contest!!!! Lotus 1
Lotus Club SoCal Lotus Club of SoCal Lotus 6
Roger Lotus Elan S3 - Rev Counter [Tachometer] needed Lotus 4
Gray_Cat Lotus Elan Fixed Head Coupe FS Malibu CA Lotus 3
catfood Lotus Ambulance on the BBC Spotted 1
Basil Lotus and Jags second try Spotted 3
Basil Lotus and Jags Spotted 14
K Lotus Espirit Lotus 1
T 550HP Audi Engine in a Lotus Elise-Exige Lotus 1
K Lotus Elite Lotus 3
toysrrus Lotus in PICKENS, SC Spotted 0
J Lotus europa 5 speed need recommendation for transmition work [Flordia] Lotus 3
glemon Business Opportunity [Not Spam, Lotus Related Lotus 4
H 63 Lotus Super 7 Lotus 4
aeronca65t Lotus Racing East Lotus 2
aeronca65t Lotus 7 renovation Lotus 2
K Heigt of a Lotus Europa? Lotus 5
Basil Lotus Evora S Lotus 5
JPSmit Vauxhall Viva Gt & Lotus 7 of sorts Spotted 3
Mickey Richaud Lotus 7 [Clone?] Spotted 7
aeronca65t Jim Clark's Lotus 25 Lotus 6
Alphonse Lotus 2-11 racing in Texas Lotus 3
D Need help with Lotus 7 rebuild Lotus 6
Editor_Reid Lotus Elite [Lotus Type 14] Lotus 7
C Glenn Stephens' Lotus Eleven Racing 1
C exciting Lotus Eleven in-car race footage Lotus 1
