Paul - just to clarify ... do you want to change your Signature, which is at the bottom of each post? (Remember, never forget, etc.)
Or do you want to change the picture (Avatar) that's under your name at the left side of each post? (The Early MG poster)
Tom M.
Tom, I only wanted to change the photo illustration above the signature, not the words. I've done this before a few years ago but forgot how to do it. PJ
OK - Edit: I just added a photo to my Signature. Definitely an honorable person.
Tom M.
The only slight hitch to what Tom described is that you can't "upload" an image from your computer like you can when you add an image to a post. When adding a picture to a signature the image must reside on some server already (like a Flickr account etc) Whereever you have the image must allow "hot linking" of photos. Some services simply don't allow this. For example, Photobucket used to allow free hotlinks but now you have to pay for pro service. If you don;t; have a way to host your image on some other service, you can email it to me and I'll upload to my server then provide you with teh URL address that points to the picture.
It is important to not that the URL you use must point to the actual picture - to to some database address. It would need to end with the actual image file name. Something like: www.someserver.com/pictures/mypicture.jpg
Lastly, I would ask that folks don't place overly large pictures in signatures becuase it gets displayed in every single post you make and if everyone uses large images in signature it gets to be a bit much when browsing threads.
Thanks Basil, I'll send it to you later as I have to get off this thing and run to town.
Just an update to Basil's instructions. If you do the Settings/Edit Signature procedure I mentioned, there's an option to upload an image (a *small* image ..). You're not limited to using the URL of an image already on the 'net somewhere. Under the text block you'll see Upload Signature Picture.
Tom M.
Thanks Tom. I was just lookign at the Image Icon in the edit window. Forgot about those other options down below.
You're very welcome! Please send gratuity to my Swiss bank account as usual.
:angel:
Tom, did you remove the photo? I don't see one.....
Tom M.
