Loose rear view mirror
71TR6
One of the few little projects left my TR6 is a loose cockpit rearview mirror. It vibrates and shakes like Charo on the Johnny Carson show. I looked at the mirror and can't figure out a way to snug it up. It appears there isn't enough resistance on the swivel ball. I can't figure out how the mirror is held into the frame. Is there a way to pop the mirror out without breaking it so I can access the ball mounting and perhaps snug it up?
RonW
71TR6
PeterK
Couchi-Couchi on your dashboard? I'd leave it alone; it's a mod.
If the ball mount is similar to a mirror mount, then there is a plastic cone that rides against the ball to give it both resistance and movement. Is there a single screw on the backside of the mirror that you can tighten?
G
Drop the whole assembly with the 2 screws holding onto your window frame. With the assembly in hand, tighten the Phillips screw holding the mirror itself. Much easier to do it this way than to try and get a driver between the mirror and the window glass. Then just snug it back up.
hondo402000
I concur tighten all screws first, I purchased a new mirrow because of the same symptoms and all I had to do was tighten the screws on the existing one, but didnt figure that out till I took the old one off, lesson learned Again, start with the simple things first and work up
Hondo
71TR6
71TR6
Yup, the screw was it. It must have loosened and I forgot that it was even there. While I was at it and had the mirror assembly unmounted, I put a dab of teflon lube on the ball to make it easier to adjust. I'm not gonna miss the whole lotta shake'n one bit! Thanks to all that replied!
Ron
G Loose lugs on rear hub Austin Healey 7
mgedit TR2/3/3A Rear Shocks Loose Triumph 16
KVH TR4/4A Loose Rear Shocks on my IRS Triumph 7
T TR4/4A TR4A with a loose rear end / happy feet. Triumph 5
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
M Loose Pilot Bushing Spridgets 1
steveg TR6 Loose wheel nuts after torquing Triumph 2
sparkydave Zenith auto choke coming loose Spridgets 2
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
SherpaPilot TR6 Steering Column Loose Triumph 8
jfarris TR2/3/3A Loose Lift the Dot Stud Triumph 7
B TR6 Boot lid thread plates loose in stiffener Triumph 1
NutmegCT T-Series Loose valve cover oil cap MG 4
Lin Post in float bowl came loose Austin Healey 6
sparkydave Zenith auto choke coming loose Spridgets 3
tinman58 General TR It was just a loose wire Triumph 15
D BJ 8 Float Bowl securing bolt loose Austin Healey 6
R water temp bulb loose Austin Healey 27
S TR4/4A TR4A Water pump pulley loose Triumph 10
T General Tech How loose can a piston liner be? Triumph 2
rustbucket Loose spokes on wire wheels MG 8
angelfj1 TR2/3/3A TR3A - Dynamo Fan is loose! Triumph 3
G 6 steering column loose Triumph 3
J What tool to get the nut loose on the steering box Austin Healey 5
jjbunn E-Type Turn Switch - loose braid for horn? Jaguar 6
Jim_Gruber Bottom Starter Motor Bolt - How do I get it loose? Spridgets 7
davester Loose manifold to exhaust connection MG 3
Johnny Door handle on BN7 came loose. Austin Healey 8
D Sway bar - BT7 - loose captured nuts Austin Healey 18
M TR2/3/3A Loose wing beading TR3A Triumph 4
D TR6 Loose TR6 Sunvisors Triumph 11
T TR2/3/3A Tr3 Radiator fan loose Triumph 33
M Fuel Line Came Loose; Yikes! Spridgets 4
M TR2/3/3A 55 tr2 loose on I 70!! Triumph 3
CCURTISS T-Series MGTC Door Latch Backing Plate [screw loose] MG 0
Indnrdr Throttle pinch bolt came loose; how to get to it. Austin Healey 4
walshja winshield washer nozzle is loose Spridgets 20
R Carburettor suction chamber cap loose - why? Austin Healey 23
charlie74 loose bonnet hinges Triumph 4
T Loose Nuts: Pedro-ized Triumph 19
A TR6 TR-6 Loose Handling Triumph 22
Woodie steering pinion loose Spridgets 18
P loose shift lever Triumph 7
simpzimmer wheel loose Triumph 4
R6MGS Ignition Switch loose.... Triumph 9
Thor Loose power at 3000 rpm's Spridgets 12
P Door Glass came loose... Spridgets 8
D TR4/4A tr4 steering - inner ball joints loose Triumph 14
77_MG_Midget I think I have a screw loose!!!!! Spridgets 15
George Zeck Loose Front End .... Spridgets 6
