George Zeck
Hi All --
Making some good progress in finishing up some loose ends on my winter projects. About to tackle the last item (where I am quite ignorant on the terminology due to the age of the car) -- the front end.
During normal driving -- if I hit a bump - the car "jumps" on me. While jacked up: move the top / bottom of the tire - I have lots of play. My thoughts are that the bearings are in need of replacement. Someone also mentioned "king pin" to me. What in the heck is this and how can I determine if it needs to be replaced?
Looked in Moss / VB and have an understanding (quite overly generic). Seems as this is an "axle" of sorts that all the suspension floats / hangs off of. How can this wear out?
Have good resistance on the dampeners. Was probably going to pull those and replace the oil and then make the call about replacing them after a few miles.
Have replaced tie rod ends / boots / bushings (inside trunion) last year.
I know all problems can be solved by throwing $$ at it -- just not trying to set a record. Thanks for the advice.
George Zeck
PS -- Haven't driven yet - but replaced rear dampeners and rear bushings.
/ubbthreads/images/graemlins/hammer.gif
HAPPY EASTER !!!!!!!!!!!!!!!!!!
George Zeck
