Dang! Thatβs a good dealJust got back from an art supply store. They have a 60% off weekend. So they are printing this at 15"Γ23"ish for $29.
As an aside, check into sign shops with wide-bed printers. I've had poster sized prints (up to 42" wide) made on HP commercial inkjet printers. Laminated, too.
GregW
I will keep that in mind but there is no shortage of photo print shops in my area. I see graphics as separate from photo printing though the printer you linked to may do the trick. Back in the day of CMYK printers, changing color pallets from RGB to CMYK wound up with huge color changes. I'd have to spend more time after the change tweaking the look back to my original vision. That HP has more color cartridges so it may be truer to the original RAW file. Still, the art department at work almost always has a similar printer that doesn't wow me. Dithering is obvious.
I keep forgetting about the resources you have around you. Real photo labs down here are kinda scarce. And only a couple I'd trust.I will keep that in mind but there is no shortage of photo print shops in my area.
Hi Guest!
