Bret
[ QUOTE ]
I know nothing about MGB suspension: However, you need to isolate exactly what you don't like about BINABOX's handling, then double check for any issues that may be causing it. Bolting on suspension "improvements" may make an existing problem worse. If the car tracks straight on a level road, then your toe-in is probably OK if you are not having excessive tire wear. If it goes through a curve fine until you hit a bump or dip, then you may have bad shocks or loose suspension components. If the car wants to wander on a staight level road, then it may need more toe in. Or... the steering rack may need to be rebuilt/adjusted to remove pinion lash.
I know you just rebuilt the car, but it doesn't mean that everything is as it should be. Double check the suspension fasteners, shocks, toe-in, caster?, camber? Then decide what you want to change. Less body roll on the cruves? Smoother ride with less jarring? etc.
Or... buy a proper Midget.
/ubbthreads/images/graemlins/wink.gif
[/ QUOTE ]
Pretty good suggestions for someone who dosn't know anything about the MGB's suspension. /ubbthreads/images/graemlins/thumbsup.gif
[/ QUOTE ]
Hi Guest!
