Hi all,
I posted a while ago about a strange state that my TR3a would get into after a thorough warm up. It runs fantastic when I first start up and run around for at least 15 or 20 minutes. Not exact on the time, and I don't think it is always consistent anyway but definitely this 'strange state' occurs well after the car is warmed up.
What happens is it is as if it is running on only one or maybe two cylinders which allows me to limp home but constantly scanning the side of the road for possible emergency pull offs. Having experienced a mechanical fuel pump failure on another old friend of mine ('63 Tbird) this seemed very familiar. I'm thinking the fuel pump is going and it's being kind enough not to strand me on the road. So I replaced with an electric fuel pump and after a few unrefreshing petrol showers while rolling around in the fall leaves and fallen oil it is working like a champ. Plenty of gas is getting to carbs. So someone suggested a stuck float valve or a maybe a SU piston that was sticking. Took apart both carbs last night and everything looked very kosher. Of course I cleaned out all passages for good luck as long as I was there.
Now I am begining to think about ignition stuff. Popped off the distrib cap and was kind of surprised to see that it wasn't all that clean in there. I have a Petronix ignitor that I put in when I got the car and it has been working fine since then. There was some corrosion showing on the rotor cap (I think that's what it is called). The thing that is plastic and conductive and swings around just inside the distrib cap and actually distributes the juice to the spark wires. I cleaned that up as best I could with some 600 emery cloth. Looks pretty shiny now and I am sure this won't hurt even if its not the problem. Also touched up the 4 contacts that this rotor arm touches. They were a little off color but not too bad. The distrib cap, wires and coil were new with the Petronix ignition stuff so we are only talking a few hundred miles on them.
In the course of replacing the mechanical pump with the electric I can testify as a reluctantly soaked witness that there are no blockages in the lines. One thing I am kind of grasping at straw with is the rubber hose that comes from the bottom of the tank to the hard line on the chassis. I have not replaced that and am wondering if it might be collapsing and shutting off the fuel under certain conditions (like when its hot?) but otherwise working fine. I haven't looked at it too closely but has anyone replaced that part recently? It seems that it would be very difficult to get to the tank side of whatever that hose connects to to replace it.
The carb side is obvious.
I haven't had a chance to drive the car since I did the carb distrib cleaning but I don't have real high hopes that I have dealt with this problem yet. One thing that makes this even stranger, to me at least, is that when it first started happening (and remember this was before the electric pump came on the scene) it would only occur in the higher gears and when I was moving along pretty briskly. The 'low end', starting from a stop, did not seem to be effected.
Most recently though, like yesterday, the opposite has occurred and it is running in 3rd and 4th like a sled on snow but apparently starving for something, or shutting down cylinders in the low end when I am starting out in 1st or 2nd.
Any ideas, thoughts, scathing criticism would be most welcome,
Thanks much,
Jim Lee
Thanks much,
Jim Lee
