Looking for a pressure bleeding system
wrenchranch
I guess I am having a little trouble getting this post in the correct place. Sorry.
I am looking for a pressure bleeding system for my 69 E Type Series ll. Does anyone have a lead?
Thank You,
Greg in Montana
Geo Hahn
each time I have had occasion to open and partially drain the brake hydraulics on my series 2 I have had to pressure bleed the fronts to get them done -- otherwise my wife could pump the pedal all day with no result.
I use a simple set-up -- an air line into a substitute cap using 1/4" irrigation hose and a double-barbed irrigation fitting. all stuff I had lying around though it could be cobbled together many other ways:
this approach just applies modest air pressure [15 lbs or less] to the top of the appropriate reservoir, hence it does not actually contact brake fluid, it doesn't even have to be perfectly air tight.
any old cap may do -- that one was for a lawn mower gas tank, the one for the clutch was a plastic top from a spice bottle I found in the pantry. I made some rubber washers from an inner tube to help it seal better. for an air supply I used a portable tank with just 15 lbs in it --- but almost any small air supply could probably be made to work [spare tire, 12vdc compressor, garden sprayer, etc].
all it has ever taken me is a brief shot of air to bleed each front wheel - I suppose just enough to overcome the m/c system. I finish with the usual pump bleed but perhaps that is not really necessary.
W
wrenchranch
Thank you Geo (George)? I wonder what you used for the pressure container? After exploring many ideas I settled on buying one from O'Reillys Auto Parts. Marketed under the Mityvac label (Model # 6400) it is indeed a pressure bleeding not a vacuum affair. First trial will be today but it seems to be pretty well made and comes with a Jaguar reservoir cap. As an aside, I have completed the rebuild of all five brake components in the engine bay. Fingers crossed.
greg in monana
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
pbraun Looking for 64 or 65 Mokes British Motor Corp 0
T Looking for a temporary cup holder - but my heart is pure Spridgets 9
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
catfood Looking for suggestions - ignition issue Austin Healey 6
W Looking for engine rebuilding 100-6 Austin Healey 12
C Looking for SoCal restoration shop Austin Healey 4
