rcufley
I am in the process of restoring a 1980 spitfire 1500. I have removed the transverse leaf spring to return it back to the way it should be and was going to replace the rear shocks. That is the point where I need a little help. Can someone tell me if the pin that attaches the lower end of the rear shock to the vertical link is a removable bolt or an integral part of the vertical link? The threads are severely stripped and something needs to be replaced. I have tapped on the threaded end of the pin with a punch and nothing appears to be moving. Thanks for any advise !!
R Cufley
R Cufley
