Gray_Cat
Welcome to the Forum Roger!
I've been where you are. So if you are interested I can can send you a 1275 "short block", the only catch is; I'm in Los Angeles. The only expense you would be liable for is the pure cost of shipping, to include proper crating of the engine. I bought this a couple of years ago from an MG Car Club member in San Diego but ended up using a different 1275 for my ongoing Bugeye project. The short block consists of: the block, crank (20/20), camshaft, oil pump, pistons&rods and timing gears. There may be a few other bits but I'm at work so can't run out to the garage right now! OH - The bearings for the crank&rods are new as are the piston rings.
You could use the head, engine plates etc. off of the engine you have and then do a wicked rebuild on it as time and $$$ permit.
To ALL: Roger has first dibs if he wants the engine, if not it is available to any other Forum member at the same "price" - I much prefer someone get it that will put it to use and not just to resell.....
Roy
Roy
:banana:
