TR6 Longer Front Wheel Studs for a TR6?
zekjet
I'm trying to find longer 7/16" front wheel studs for my TR6. Just added new alloy wheels "Konig Rewinds" and have made the clearance adjustments with the upper A arm and turned around the balljoint bolts, but in reverse at full lock, the rim will make contact with the ball joint bolt, so I am trying to add a hub spacer, which leaves my 1.5 inch studs a little to short for the lug nuts. I've called the big 3 and no luck. Any suggestions would be greatly appreciated.
Thanks for the reply! ARP has pretty close to what I need, I'm concered about the knurl diameter, the stock stud is approx. .510 and they offer a diamter's @.48 and .56 on up. I suppose I could ream the stud holes on the front hub for a proper seat.
When I change Sprite hubs to the 100-7701, 7/16" studs, I have to open the holes up to .453" to accept the larger (.486")knurl.
Incidentally, those are GM wheel studs, so are also available at parts stores, in the stock material.
Jeff
