DW wants to try using the soft top instead of the hard top on our Longbridge BN4. So, I'm restoring the frame and have a detail question. There are two pegs at the bottom of the frame which slide in the slide rails, mounted to the body. I had to buy new ones. Each peg has two washers and a spring. My question is; which order do these go on the peg, going outward from the frame:
Thanks!
- frame, spring, washer, washer, peg head,
- frame, washer, washer, spring, peg head, or
- frame, washer, spring, washer, peg head?
Thanks!
Hi Guest!
