Long wheel base bugeye
I noticed (via youtube) that David (bugeye guy) is having a sprite's wheelbase lengthened by 5 inches for a client. What are the tradeoffs in doing such a thing. Assuming the pedal position and steering wheel works for your body; what are the negatives?
drooartz
I've been following that too, Trevor. Interesting project.
Will be interesting to see how that car handles once it's done -- I'd expect that's enough wheelbase change to be noticeable, though for better or worse I don't know. Hope there's plenty of reenforcement in what they're doing, would hate for it to fold in half once done.
Hope it turns out well.
Trevor Jessie
Both my spridgets have been constructed by splicing two different cars together. I purchased both of them this way. Neither has shown any signs of failure. My concern would not be about the strength of the car, but (as you said) the handling.
I guess he is going to make custom sidescreens as well as a custom top.
Jim_Gruber
This must be for one really tall customer. Is there a link for that YouTube Video Trevor?
AN5Sprite
grrrrrrroooooaaaaan :pukeface: that's my reaction.
If you're too tall and too old, too bad. Get yourself an MGB. No sympathy.
I get what he's doing marketing wise but, to me, reverence for the marque should trump this kind of modification/desecration.
(If that makes me as a purist, so be it.)
It's a spec build, not a customization for an existing customer. Somehow that makes it worse to me.
Gerard
A real bugeye guy would cut 5 in. out of his legs to fit. :jester:
Hey, why not cut it lengthwise to and widen it for all the fat, ummm, I mean 'broad shouldered' guys that want to stuff themselves into a Bugeye... what the ****, lets make it as big as a Big Healey while we're at it...
A new low in the hobby...
:pukeface:
AN5Sprite
My initial reaction was negative. Now that i've stood before my own car with a tape measure....
I'm horrified. 5" to the door/etc is ridiculous. 2" maybe, but then why do all that work for 2"?
Exactly. Don't.
JPSmit
OK, I'll be contrary and say I think it is pretty cool. Yes, for the money etc. etc. I'd probably just upgrade to a bigger car but, we've seen Jag powered Sprites, Zetec, Hardtop sebring sprites, so, why not? They aren't THAT rare and the beginnings at least looks like it is being done to a high standard. It would certainly be more interesting at a car show that 3 dozen identical cars (including my own). I'm going to follow it.
Jim_Gruber
At 5'6" on a good day I don't see how someone 6'+ fits in this car. I drive with Miata Seats as far back as Seats will allow with rollbar in place. Rollbar does limit how far seats can recline.
58Custom
I'm agnostic on the stretch, but would it kill the guy to zoom out? Man, all of those tight shots in the videos and the constant panning make me frustrated and nauseous.
Trevor Jessie
I'm 5'10" and almost 13 stone. The bugeye seems spacious to me, but my '70 Midget feels a bit cramped (but more comfortable).
Jim_Gruber
Trevor, I will be interested in seeing how I fit in Bugsy II once he comes home. I can't recall sitting behind the wheel of a Bugeye, it's always been in a Spridget. The Miata Seats in Bugsy are definitely roomier than stock high back with headrest later seats that were installed in Bugsy my '68 Sprite when I acquired him.
aeronca65t
If I wanted a skinny, long car, I'd buy an MGA :playful: ( a fine car, by the way).
Honestly, if I really wanted a Spridget that was easier to get in and out of (and I had a huge budget), I'd cut back the area where the door hinges are and just make the door longer at that end (yes...this would require fender mods and all sorts of cowl reinforcement and modification).
Once you're actually IN a Spridget, there's a fair amount of leg room if you have the thinner seats (like in a Frog). I'm a bit over 6' and weight around 210 and it's not even a slight problem for me......once I'm in.
But getting my left leg in at times (LHD car) can be a challenge.
Maybe because I'm 62, but even when I was in my 20's, it was a challenge.
My MGB and my Miata are much easier.
Trevor Jessie
At one time I gave much thought to that, but I decided it was well beyond my limited engineering knowledge. My plan just kept getting more elaborate. The benefit of doing such a mod is that it could hide the a-post to make the car's lines much smooth
B TR6 Crankshaft long seal surface Triumph 5
jfarris Message too long error FORUM Navigation Questions 8
L My 1951 Triumph long ago British Motorbikes 0
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
W Generator and Starter Long Bolts Spridgets 0
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
Zitch Engine Oil Leak After Long Drive Austin Healey 19
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
G TR2/3/3A Finding a long lost TR3 Triumph 4
R The long road home Spridgets 1
Y MGB An odd (and probable long-shot) request... MG 5
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
T BT7 throttle relay levers short and long Austin Healey 2
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
Michael Oritt Post- Open Roads 2002: Tahoe to MD the long way Austin Healey 19
R TR2/3/3A Restoring a 54 TR-2 Long Door Triumph 10
boxofparts TR2/3/3A My long term 30 yr project Triumph 5
K For Sale Long and short TR3 and 4A Intake manifolds Triumph Classifieds 0
Joe Schlosser Thoughts on a long traffic Light Spridgets 11
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 22
D Long Lost Midget Spridgets 0
E Long lost Sprite Spridgets 10
roscoe Leakdown test [long read] Austin Healey 11
aero3113 Healey Shop on Long Island Austin Healey 9
britlover Wanted TR4 Hood long bubble Triumph Classifieds 0
D MGB Painted rubber bumpers. How long will they hold up? MG 1
T C42 BJ8 generator long screw needed Austin Healey 2
PeterK General TR Time for a long ride Triumph 3
D After a long break.... Spridgets 6
Lotus Club SoCal Ballast Point Long Beach Social Lotus 2
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
L TR6 need help on long dead TR6 Triumph 16
Sarastro Morris Minor in Long Beach, CA Spotted 1
D TR4/4A extra long oil filter attachment stud Triumph 9
D TR4/4A flywheel bolts maybe too long Triumph 15
Sarastro Red TR3 in Long Beach, CA Spotted 0
Jim_Gruber I woke up Bugsy this afternoon after about a month long nap and he was cranky Spridgets 7
TomMull Post-War Other Herald: Holy Moly! [Why it took me so long to make the accelerator bracket] Triumph 2
Marla TR4/4A Take the long way home Triumph 11
K TR2/3/3A How long should an SU damper top up last? Triumph 22
steveg Very interesting very long blog posting - racing oil and zinc Austin Healey 44
Got_All_4 TR2/3/3A Tr6 a type overdruve in my tr3 too long Triumph 10
TomMull TR2/3/3A Long Door anyone Triumph 16
B TR2/3/3A TR3A VS TR4 Long Tube inlet manifold Triumph 8
KVH TR4/4A Long Speedometer Cable for OD Transmission Triumph 10
