Blackjokr said:I guess that answered that question, Mickey..lol..thank you I will try it. Are they normally grounded to wotk? I ask only because the Moss Motors tech said you don;t need it, but I can't imagine that you don't. Not sure how many electrical devices can run with just a hot wire. How else would it complete the circuit?! Do you know if typically the electronic pumps require the ground on the other lug? I even asked th MM tech why do they have a separate lug which looks like it is ground if you don't need it? I am assuming there used to be some sort of metal bracket the pump was attached to that grounded it automatically then thy put the rubber sleeve and required a separate wire?
Unless it's grounded through the mount or somehow through the fuel line connection (?), it has to have both positive and negative supplied somehow.
Blackjokr said:these forums are like having your own team of experts and awesome dudes! thanks I'll give it a shot and post back.
No expert here; I'm still groping around in the dark like many! I do ascribe to the "Even a blind squirrel..." message, though! :wink:
