Loctite for front shock bolts
I'm using Loctite Nutlock on mine and they are torqued appropriately for the bolt size. They're tight right now. :encouragement:
I've used blue Locktite with hardened flatwashers (only) with bolts torqued to 35 ft-lbs for many years and miles and never had one come loose.
Thanks, Bob - will give that a go.
"Spot-facing" the shock also helps. The surface is uneven and this takes care of that problem. I also did the rear shocks the same way. I had to use AN, "aircraft spec" washers because the standard hardware stuff wouldn't work.
Patrick,
The pictures show a thin and thick washer. Could you explain a little more?
Steve,
The thin washer is the "aircraft quality" one and the washer on top of it is a standard lock washer. A friend on mine has a special cutting bit & drill press to cut the shock metal casting and in doing so it removes the imperfections and irregularities on the shock metal thereby creating a perfect surface for the shock bolt & washers to "seat" against the surface. I can provide more detailed info when my friend gets back into town showing the equipment we used if you would like that too?
Steve,
Patrick,
Not necessary. Thank you for the offer.
My setup's a little different as I have a tube shock setup (homemade - similar principle to Udo's) using long bolts through the stanchions. One of these came loose for the first time in 10 years. I had been using belleville washers under the bolt heads and had had no problem but switched to grade-8 split ring washers and one of those came loose.
Since your setup relies on the friction of the split ring between the bolt head and aircraft washer, I'd wonder if substituting inner- or outer-star washers might give better friction. IMHO split rings aren't that good if they can't bite into both surfaces. The friction is only at the split, not all the way around, as it would be with the star washer or belleville.
Not to be argumentative here - just thinking "out loud". :smile:
Patrick,
I had actually thought about doing away with the split ring, but keeping the flat washer, and buying some aircraft bolts with the "holes" in the bolt heads and then safety wiring them with .032 or .040 safety wire. I haven't seen that done before on a Healey but if it works for aircraft it should work for Healey's??
Interesting post. Are Healeys prone to having the shocks come loose over time? I've never heard this before. PJ
Do shock bolts come loose? I'd say from my 51 years of ownership, yes. Both front and rear shocks loosen over time. After I had all shocks rebuild two years ago, I used blue locktite on all bolts and they were still tight when I removed them at the beginning of the restoration this year. Several years ago, I replaced the stock cap head bolts on the rear shocks with Allen head socket head bolts. They are much easier to tighten.
.... One of these came loose for the first time in 10 years. I had been using belleville washers under the bolt heads and had had no problem but switched to grade-8 split ring washers and one of those came loose.
... - just thinking "out loud". :smile:
Just thinking out loud here: Why not go back to the belleville washers?
I agree with using the blue Loctite, just make sure the threads are clean.
This will (re-) kindle a long-running, er, 'discussion.' In theory, a bolt in tension is held in place by steel's elasticity and the bolt being stretched. Hence, 'torque-to-yield' bolts and lack of any sort of lockwasher on critical junctions like head studs. So, a properly torqued bolt in an application where there is no 'give' besides the bolt stretch lockwashers aren't needed, and may be detrimental. Either the factory or the DPO had put split lockwashers under the bolt heads on my front shocks, and the washers had dug into the soft metal of the shock body, pretty much making them useless as far as preventing the bolt from coming undone (facing these spots is a good idea, IMO, but don't take off too much metal). I still have the original shock bolts, which I believe are the British equivalent of our Grade 8.
The reasons for using Grade 8 flatwashers is a) plain steel flatwashers are relatively soft and will compress and relieve tension on the bolt and b) plain steel washers will deform and release tension on the shock. Since a Grade 8 is larger in diameter than the bolt head, you are effectively increasing the clamping force. For (a wildly approximate) example, if the area under the bolt head is one-half inch squared, the bolt tension is 500psi, then if your Grade 8 flatwasher is one inch squared, you are effectively putting 1000 pounds of force on each corner (the area factors cancel out, if you do the math). This reduces the shock's ability to 'wiggle and squirm' its way loose. The threadlocker is just insurance, but be sure to guesstimate its effect on the torque spec (less than oil, but greater than dry).
My experience is this does not quite apply to the rear shocks, which have unsecured nuts on the backside of the mounts. I tried the Grade 8 bolt/flatwasher/threadlocker-only approach, and a shock worked loose. I still use only a Grade 8 lockwasher under the bolt head, but I use a splitwasher under the nut. I think only using threadlocker on the nut side allowed the bolt to rotate and work loose; the split lockwasher prevents that.
I don't think safety-wiring is appropriate in this case. Safety wiring only prevents a bolt or nut from coming loose entirely, which is why it's widely used in aircraft where the results of things coming apart often ain't pretty. The safety wire itself is not strong enough to hold the torque on the bolt/nut, and there's still some give in the wire even when properly twisted (I believe the 'spec' is 9-12 twists/inch). Also, using safety wiring properly is almost a course in itself for aircraft mechanics--you always have to wire in the direction that keeps tightening tension on the bolt/nut, and the wire must be properly secured to an anchor, or another bolt/nut--and requires a jig to drill proper holes in the bolt heads and/or nut. One good thing: safety wire-twisting pliers used to be very expensive, but you can get decent ones at Harbor Freight at a fraction, and they work well enough.
That's interesting - suspect there might me more to it. If you put a bolt through a steel cone with 5x the area of your bolt head, would you have 5x the pressure. Doesn't feel right, but have no idea where to find a citation on it.
Some years ago when I put new shocks on I decided to use locktight. When I recently restored the car I did not take the front suspension apart because I new it was good. And the shocks "appear" as tight as you would want them. I say appeared because even when I first applied the locktight I knew that I would never retorque the bolts because in doing so I figured it would break the locktight loose. So I was hesitant to use the locktight but I did. So after all this time the front end is tight and smooth and I'm sure I'll know it when something loosens up. I suppose if I was concerned about it I could pull each bolt clean them and reapply the locktight and retorque. Dave.
You can always re-torque after you've used Loctite because it still works. You can even take a bolt out and put it back in and if Loctite is still on there, it'll still work, just not be quite as strong. It's very good stuff.
Agreed. I think I confused tensile strength with clamping load: https://www.spaenaur.com/pdf/sectionD/D48.pdf I was confused clamp force with hydraulics where, of course, pressure can be amplified by varying surface areas.
At any rate, Grade 8 washers aren't that much more expensive, and if your purpose is to spread a load they're the way to go (why even stock mild steel washers?).
Just to add a different twist. I have used nord-lock washers for years on areas of high vibration. The come in either stainless or zinc coated steel which is compatible with grade 8 hardware. You can buy them from McMaster Carr
John
Hi EV, I can agree with you, I have noticed that attribute. But I believe if I'm going to use it I would like it to be as strong as its original intent. Dave.
Note blue Locktite now comes as a tape (sort of like teflon tape). Expensive as all get out, but if you don't like most of it dripping off onto your shoes ...
