I've used blue Locktite with hardened flatwashers (only) with bolts torqued to 35 ft-lbs for many years and miles and never had one come loose.
"Spot-facing" the shock also helps. The surface is uneven and this takes care of that problem. I also did the rear shocks the same way. I had to use AN, "aircraft spec" washers because the standard hardware stuff wouldn't work.Thanks, Bob - will give that a go.
Steve,Patrick,
The pictures show a thin and thick washer. Could you explain a little more?
Steve,
The thin washer is the "aircraft quality" one and the washer on top of it is a standard lock washer. A friend on mine has a special cutting bit & drill press to cut the shock metal casting and in doing so it removes the imperfections and irregularities on the shock metal thereby creating a perfect surface for the shock bolt & washers to "seat" against the surface. I can provide more detailed info when my friend gets back into town showing the equipment we used if you would like that too?
I had actually thought about doing away with the split ring, but keeping the flat washer, and buying some aircraft bolts with the "holes" in the bolt heads and then safety wiring them with .032 or .040 safety wire. I haven't seen that done before on a Healey but if it works for aircraft it should work for Healey's??Patrick,
Not necessary. Thank you for the offer.
My setup's a little different as I have a tube shock setup (homemade - similar principle to Udo's) using long bolts through the stanchions. One of these came loose for the first time in 10 years. I had been using belleville washers under the bolt heads and had had no problem but switched to grade-8 split ring washers and one of those came loose.
Since your setup relies on the friction of the split ring between the bolt head and aircraft washer, I'd wonder if substituting inner- or outer-star washers might give better friction. IMHO split rings aren't that good if they can't bite into both surfaces. The friction is only at the split, not all the way around, as it would be with the star washer or belleville.
Not to be argumentative here - just thinking "out loud".![]()
Just thinking out loud here: Why not go back to the belleville washers?.... One of these came loose for the first time in 10 years. I had been using belleville washers under the bolt heads and had had no problem but switched to grade-8 split ring washers and one of those came loose.
... - just thinking "out loud".![]()
That's interesting - suspect there might me more to it. If you put a bolt through a steel cone with 5x the area of your bolt head, would you have 5x the pressure. Doesn't feel right, but have no idea where to find a citation on it.
