Hello all,
I was reading a couple of wiring post on the boards today and hoped that all the wiring gurus out there might be able to assist me.
I have a 76 B with and issue that involves the lighting/ignition (I think).
the problem is that whenever I have the key in the on position the parking lights are lit irregardless if the switch is on or not. Working the switch turns on and off the headlights and the dimmer/high beam function works propertly and the car starts and runs fine. The problem occurs when I try to shut the car off with the headlights on. If I turn the ignition off with the headlights on the car continues to run until I turn the headlight switch off.
Is this just a bad switch which always leaves the parking lights on when the ignition is hot and backfeeds the ignition circut when the lights are on and the key is off, or does this problem hint of a more serious wiring issue with the ignition switch itself.
Any thoughts you all may have would be most appreciated
