Is there an easy way to determine if I have a stock or lightened flywheel in my BJ8, without taking the car apart to see.
When shifting from 1st to 2nd, RPM drops so quickly that I'll need to increase the RPM when the clutch is in to get it into 2nd. And even then the car needs to drop in speed for that to happen.
Other Healey's, 1st gear, clutch in, slides right into 2nd, no drop in speed, no gas on the pedal until after it's engaged.
Transmission was rebuilt and I helped the professional do it. Even after the rebuild, it doesn't always want to go into 1st every time.
Complete stop, shift into 2, 3 or 4th, then into first. Sometimes it just will not slide in. Makes me very nervous when someone is behind me at the light.  While waiting, I'll test it a couple times, works fine, then when it's time to move, it will not go into 1st and I end up starting in 2nd.  But every time, going into 2nd, RPM drops very quickly and once in 2nd the car has slowed down for that to happen. If I try and force it in with more gas, the car will buck once in.  A friend drove my car yesterday and mentioned, that's not right. I think you have a lightened flywheel and that's why you aren't carrying momentum thru to 2nd.
On an up note, very happy with the way the car speeds up very quickly on the freeway, when in 3, 4 and 4th overdrive.  Really a fun drive.  Maybe that's what Healey's do, or maybe because I have a lightened flywheel?
Is this a flywheel or transmission issue?
Thoughts?
