AUSMHLY
Hello,
Seems almost every time I drive over railroad tracks, the rear shocks can't seem to handle the travel and I get a bang sound.
I remember this sound when my dad had his Healey. Is this common or is it time for new shocks?
When pushing down on the front and rear wings and they seem to travel and return at the same pace and distance, level out after a couple times. (I think the front shocks are fine, but if they are also worn out, then this comparison is no good.)
Before I remove the rear shocks and send them out to be rebuilt, I thought I'd ask here about adding oil. The rear shocks are not leaking.
I removed the top fill plug and slid a wire down. The wire bottomed out at about 1 1/4" No oil on the wire. If I move the wire around a bit, it will get past what ever is stopping it and 1/4" deeper I hit oil.
Where is the oil suppose to top out from the plug?
If it is low on oil, how can that be, if it shows no sign of leaking?
Could this be as simple as adding straight SAE 20w oil?
If so, how far down below the fill plug?
Thanks you.
Thanks you.
