Lever for making tight turns?
john_j
Just a thought caused by the thread on rear disc brakes - in the UK the lever on the floor between the seats is called a handbrake, hence if you want to make the car point the other way quickly you do a handbrake turn (dip the clutch, swing the wheel over, pull the lever up)
What to americans do - is it an emergency brake turn?
Someone at an autocross caught me on film doing a handbrake turn in my Healey. I thought I had those pictures online and could post them; must be on my computer at home. I'll try to get them up on the web...
Current proper name is :
Rear expansion plate or caliper pressure directional movement enhancement.
[ QUOTE ]
[/ QUOTE ]
I wouldn't like to have the co-driver shouting that at me as I headed towards a hairpin!
I have heard that some of the rumrunners (during prohibition) set up two hand brakes, one for each rear wheel. They would lockup the inside wheel in a turn to out maneuver the police. I don’t know how effective if was.
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
It does cause problems but if we all are not politically correct... well what can one say.
Some drivers are also referring to this as MREPCPDME. And I made a huge mistake it should be
Manual rear expansion plate or caliper pressure directional movement enhancement.
Here's a "captured" handbrake turn at a 1985 SCCA Autocross. Use course worker position for reference /ubbthreads/images/graemlins/driving.gif
The "obstacle" was the large cone just to the left of the car in the second picture (also barely visible just forward of the left fender mirror in the first picture).
From what I have read, the "bootleg" turn, was named for the "bootleggers" (moonshine runners). Or maybe they got the name because they used the turn. That's a whole new question though.
They used the turn to reverse direction quickly on narrow roads in order to lose the revenuers when they had to make multipoint turns because they didn't know how to "bootleg", or to force the revenuers off the road because they didn't want to have a head on collision. heck of a way to play chicken!
There has to be someone close to the moonshine museums down n Georgia that could learn more. Or at least tell me if I'm full of hooey.
Oh, and I remember Rockford doing it in reverse most of the time.
