mightymidget
Uploaded with ImageShack.us
I Dropped this bugeye rear end off at a forgein car shop, they let it sit for 30 days and didn't touch it. So I picked it up from the shop to rebuild myself now. This is a 1/4 spring Bugeye.
This big 2" nut. which way do you remove? and what do you use to remove it with? The only tool I have that fits is a hammer and chisel? can you buy special tool cheaply?
This rear end is a 9/38 what gear is this? I purchased one off ebay that was suppose to be a later model but the numbers are the same.
Any suggestions or advice will be well recieved right now
The bearings behind the nut, should I replace them?
Also I have a set of later model backing plates, since I need to replace everything in brakes should I upgrade
