Green bulbs? I didn't use green bulbs. There is a green lens in the instrument back that makes the light appear green.Elliot why did you go with green bulbs? Got may dash all apart to remove heater motor. Wiring oil soaked from oil pressure gauge leaking. Anyway decided to convert bulbs while i have easy access to all gauges.
I'm thinking of going white and a bit concerned that they my be too bright. I like 72djm76dkm converting to a digital rheostat. Wonder where he got that done. Now not all LEDs are dimmable. Do you know if yours are? I also saw on the listing a cool white bulb and wonder if it's not as bright.
I really don't know if they are dimmable since my rheostat doesn't work. If you find any info on a digital conversion I'd like to see it.
Check your PM
Hi Guest!
