AUSMHLY
Doing some research into upgrading the Healey headlights.
In order to do that, the stock seal beam housing needs to be replaced with one that can accept an H4 bulb.
1. Halogen set up, wire gauge should be increased, add replays, add new wire from solenoid to relays, inline fuse.
2. HID set up, wire gauge should be increased, add replays, add new wire from solenoid to relays, inline fuse.
3. LED's can use stock wire, don't think relays are needed, no inline fuse in that case.
Has anyone changed to LED in their Healey or regular driver?
