While I do try to keep Baby Blue relatively stock, I had been mulling upgrading the exterior lights to LEDs to help make the car more visible. Since this car's purpose is to be driven, safety trumps originality for me. Joe Parlanti of Veloce Solutions was looking for a Spridget as a test bed so he could start offering exterior light packages for them, so I offered him Baby Blue as his guinea pig. Joe is a Sunbeam guy, who has a spectacular Tiger. Joe lives nearby, so he stopped by my house and we did the install together.
Here's some pics of the installation:
LED on top for the turn, Dual-type LED for the driving/brake light below
DSC_0046 by David Cohen, on Flickr
Front turn signal. These were probably left on the car during the repaint as they were a pain in the butt to remove. The gaskets were completely dry rotted and gooey. New ones on order!:
DSC_0049 by David Cohen, on Flickr
Even in a picture, you can see this lights are considerably brighter as the amber lenses now look bright yellow:
DSC_0055 by David Cohen, on Flickr
..and much brighter taillights and tag light:
DSC_0056 by David Cohen, on Flickr
The one issue we had was with the hazard lights -- I could not find the hazard flasher at all, and the hazards do not like the new turn signal relay. The only thing I could figure was the hazard flasher is located behind or even in the radio box? Right now, I can live without the hazards, but I do need to replace the flasher with an LED relay.
With all this work on the exterior lighting, the next logical step is to upgrade the headlights. My understanding is that new headlight relays would need to be installed that run directly off the battery. Has anyone done this? Electrical stuff isn't my strong suit...do you need an engineering degree to replace the relay?
If you're interested in reaching out to Joe, you can hit him through his website at: https://velocesolutionsllc.com/ - You can see his Tiger on the home page. If you want to go the LED route, he's definitely the guy to talk to.
DSC_0046 by David Cohen, on FlickrFront turn signal. These were probably left on the car during the repaint as they were a pain in the butt to remove. The gaskets were completely dry rotted and gooey. New ones on order!:
DSC_0049 by David Cohen, on FlickrEven in a picture, you can see this lights are considerably brighter as the amber lenses now look bright yellow:
DSC_0055 by David Cohen, on Flickr..and much brighter taillights and tag light:
DSC_0056 by David Cohen, on FlickrThe one issue we had was with the hazard lights -- I could not find the hazard flasher at all, and the hazards do not like the new turn signal relay. The only thing I could figure was the hazard flasher is located behind or even in the radio box? Right now, I can live without the hazards, but I do need to replace the flasher with an LED relay.
Hi Guest!
