LED Brake Light Bulbs?
CinneaghTR
This is a spin-off from the instrument bulb discussion.
Has anyone mounted modern LED bulbs in their brake and turn signal lights? I am considering this for more visibility at night (heck, as well as for the day for that matter) and would think that it would not deter from the originality of the car since it is a straight plug-in arrangment. Anyway, I would like to know if it works and if it is indeed an improvement.
Having said that, one of my future projects is a generator rebuild, contact cleaning, etc.
Andrew Mace
We had a similar discussion on this very forum back in June. As I did then, I will do now and post a link from a bulb vendor site with information on use of LED bulbs -- https://www.superbrightleds.com/carbulb-notes.htm -- and let you make your own decision. /ubbthreads/images/graemlins/confused.gif
CinneaghTR
CinneaghTR
Thanks guys, I'll keep you up-to-date. Now, if I could just make my headlights as bright and annoying as modern cars...
Andy, I'm a little embarassed since research is what I do for a living. Anyway, I'll use the forum's search function next time. /ubbthreads/images/graemlins/blush.gif
Andrew Mace
[ QUOTE ]
[/ QUOTE ]Jeremy, don't feel badly! I don't really do a lot of research for a living, but I am a librarian. In this case, though, it was a matter of my remembering that I'd found and posted that link before, after wondering about LED bulbs myself.
Headlights, though, are simple. You can easily buy 7" sealed-beam halogens almost anywhere, or (depending on your state's laws) you can go the next step and buy REAL headlights that take H4 bulbs. Either is a respectable improvement over the tungsten-filament sealed beams that came on our cars when they were new!
Dave Russell
Yoda - R.I.P
[ QUOTE ]
[/ QUOTE ]
I have found that the trendy blue headlights, while certainly being annoying to oncoming drivers, actually put less usable illumination on the road where you need it. Something about eye sensitivity to various reflected light frequencies?
Tomster
Most bayonet based LED replacement lamps have all the LEDs facing outwards, the Autoilumination link provided above by Ab Crevoiserat, shows LEDs that are set up in as close an aray as a conventional tungsten bulb therefor should provide better or more even illumination in the reflectorized (chromed) interior lamp holders or tail lights.
The thread about guage illumination also discusses the possibility of manually re chroming the lamp holders fixtures using "Bare Metal - Chroming Foil"
You can also get more info here at BCF by doing a topic search under "Augmented Rear Signals"
foxtrapper
LED's are very directional. They are bright head-on, and quite dim when you move slightly off center. Because they are facing out, they will not use the lamp reflector, creating a tiny brake light instead of the full sized one.
I've seen them in use as you describe, the results were poor. A bright little light when viewed straight on, all but invisible when one lane over. Not good imo.
The expensive cluster units with LED's pointing out in all directions worked better, but still were not as effective as regular bulbs.
LED lamp assemblies like those used in many commercial trucks work well. But the replacement bulb units do not.
Brosky
Here is my LED light bar and rear brake lights (stock old bulbs) with brake applied. It doesn't appear to be much different in the photo, but those following me in the fog said they could see the LED bar clearly,but not the brake lights.
Brosky
Jeremy: Here is the company. Really nice people.
https://www.cfrlights.com/sdc.html?tp=CONTINUE+SHOPPING#15_LED_Ultra_Light_Bar
It's the 15" High & low intensity, which means it works on the parking and brake lights. Three (3) lights for parking and full across when brakes are applied.
I understand that they may have a unit now that includes turn signals on the ends. These draw virtually no amperage, so that is not a worry when you install.
T 3rd brake light or LED's Austin Healey 28
B Cheap 12 light LED 3rd brake light Triumph 3
P LED Brake Lights Austin Healey 2
J LED Brake / Turn Signal Austin Healey 4
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
I TR6 suggestions for brake LED bulbs Triumph 13
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
B Positive-Ground LED Light Strip Austin Healey 8
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
J LED lights for PL 700 Restoration & Tools 12
Guido36 LED Headlight Upgrade Austin Healey 1
bighealeysource LED Instrument Lights Austin Healey 12
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
BoyRacer LED Turn Signals Austin Healey 5
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
B TR6 LED Headlights Thouights? Triumph 17
T Decreasing Intensity of LED Lighting Austin Healey 3
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
johnrip Wedge TR7 led light conversion question Triumph 1
ckeithjordan TR2/3/3A LED Flasher Problem Triumph 13
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
Lukens TR2/3/3A Led flasher relay? Triumph 3
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
R TR2/3/3A Positive-ground LED lights Triumph 13
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
Bob_Spidell LED Headlamps Austin Healey 14
Gliderman8 TR6 Correct LED flasher relay Triumph 6
N Charging warning light LED conversion Austin Healey 29
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
Joe Schlosser LED Turn signals Austin Healey 9
Joe Schlosser LED flashers Spridgets 2
Gliderman8 General TR Let there be [LED] light! Triumph 18
D LED shop lights Restoration & Tools 10
GTP1960 TR2/3/3A LED headlight question Triumph 11
gbtr6 TR6 LED light bulbs questions Triumph 20
Rob Glasgow E10 Base LED Dash Bulbs Austin Healey 17
Marla TR4/4A Led dash lights Triumph 0
jfarris TR2/3/3A Moss LED Tailight Kit Triumph 4
P LED Dash Lights Spridgets 1
K TR2/3/3A LED dash bulbs again? Triumph 2
gbtr6 TR6 LED Dash Lights Triumph 8
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
D TR2/3/3A TR3 LED Lights? Triumph 5
