Leave well enough alone? (ignition coil)
NutmegCT
Bronze
Grumble grumble.
Coil in my 1957 Morris was leaking oil, altho' the engine started and ran well.
Ordered new coil from RockAuto, same mfr and model as leaking coil. Arrived in 48 hours!
Put in new coil - dead as a doornail, no spark. Put old coil back in, engine started w/o problem.
Tried new coil again - still no joy. No spark.
Grumble grumble.
As another BCF member says - if there's an ignition problem, it's the coil. It's always the coil.
Thanks JP. Does the Bosch coil you linked have internal ballast? or does it need external ballast?
Thanks.
Thanks.
Internal Ballast - the Midget had external so it is in place and bypassed should I need to reinstall the old one -which is in the parts bag
