Keith_M
I've noticed that my '65 Sprite is starting to lean towards the driver's side a little. I'm assuming that this is because the springs are getting weak (the car is solid -- no rust to allow sagging).
Is this likely to be only the rear springs? Or do I need to replace both the rear and front springs? I suppose I could just replace the rear springs and see what happens, but I thought I'd check and see if others have had experience with this problem.
Keith
Keith
Hi Guest!
