Would a carb mixture on the lean side cause a higher idle? Would a leaner mixture create a situation where the car would be harder to start even with the choke knob pulled out all the way? (linkage is set up correctly) Car wants to idle around 1200+ rpm and will die out if I drop it to 800. The plugs do not look white but relatively clean but not really a light brown. I do have a mild street cam so I suspect that a bit higher idle might be suspected because of that. Any thoughts? Karl
