V
vagt6
There's water seeping out of the top of my heater control valve, which occurs when I tried to turn the valve to the "off" position to delete the heater summer driving.
It doesn't leak unless it's turned 100% to the off position. I have it turned about 90% off now, which lets some heat into the car but doesn't seem to leak. But when it leaks it's a pretty good stream which gets on the manifold and steams up, not good.
What gives? There's not much to go wrong the valve assembly as I look at the Moss catalog exploded diagram (p. 20). Can it be fixed, or is it time for a new valve, gaskets, etc.???
Anyone have this experience?
Thanks!
Thanks!
Hi Guest!
