Hi everyone. First, thank you in advance for your input. I'm slowly rebuilding a '62 Midget that has a very leaky smoothcase transmission.
1. Does the gasket set advertised in Moss or Victoria for the ribcase also fit the smoothcase?
2. How difficult is it to install the gasket set? Can you merely split apart the halves of the transmission (to get to the center gasket) or is this quite elaborate?
3. The largest leak seems to be at the input shaft, but I don't even see an oil seal here. Is there supposed to be one? When I tip the transmission on either end, gear oil flows out freely from around both shafts.
4. I can wiggle the input and output shafts (pardon my lack of technical terms) more than 1/8" in any direction. Am I in trouble or is this normal?
Thanks!
Mark
Thanks!
Mark
