Here's my take on gaskets and "sealers". <span style="font-weight: bold">It's the gasket that does the job.</span> If you have to use any type of sealer to get a gasket to stop leaking, something is not right. With a pan gasket, the usual problem is that the pan has become distorted by to much torque on the bolts.
Remove the pan, and with a hammer and backing steel, you need to flatten out all those upward protruding dimples on the pan where the bolts went through. Check you work by putting the pan upside down on a flat surface. Then make sure that the block surface is nice and clean.
Once that's done, what I do is glue, yes glue the gasket onto the surface of pan. I usually use something like 3M weatherstrip adhesive. I don't want the gasket walking while I put it into place. If I was doing this with the engine out and on an engine stand, I probably wouldn't glue the gasket on.
Before putting the pan in place with the glued gasket on it, I smear the gasket with a thin layer of heavy grease. This will prevent the gasket from sticking to the block in case you have to remove the pan in the future. This works great with valve covers, as you take take them off multiple times without having to install a new gasket...just re-smear it with the grease.
Start all the bolts, run them snug, and then torque...book says 16-18 lb/ft.
This is how I did all the gaskets on my engine rebuild, and (knock on wood) I have virtually NO oil leaks...yes there is oil in the engine, I just checked it on Saturday.
