Well I woke the healey up from the cold Chicago winter. Jumped in and the clutch went thunk to the floor. A look in the resevoir revealed an empty hole. My local mechanic filled it with Dot 3 and told me that I had a very minor leak hardly worth fixing.
Question: Does this seem right to you? And if I do need to fix it how much do you think it should cost? Any advice much appreciated.
Cheers
David.
Cheers
David.
