floyd
I have a question on my leaking fuel pump on my 75 TR6. I'm not sure where it is leaking from because it was getting dark outside. Looking at the Bentley, could the only 2 places it be leaking at is cover/upper body or the lower body/upper body joints, and maybe just needs to be tighten at these places. The car seems to run fine so can that eliminate the diaphram being bad. And if it was bad would it cause a leak? One more question..... Is it possible for fuel to leak into the block via fuel pump internally? Thanks for any help.
