jfarris
1956 TR3, SU H6 carbs.
I recently filled the tank and immediately got a gas smell in the garage (wife is unhappy). There appears to be some seepage from the top of the fuel pump. I tightened the screws on the main body of the pump, may have helped some, but still seeping. I also have some fuel on top of the sediment bowl which makes no sense as there is not an opening there.
I looked in Moss' catalog, they have new repo pumps for $31 and rebuild kits for $13. The rebuild kit has a diaphragm and check valves but no seal for the diaphragm shaft. Can I assume that it has all the other required gaskets?
Has anyone else had this problem?
What do you have for the "tap" to turn off the flow of gas, the original style, a newer commercial shutoff, or nothing? I currently have nothing which is a problem with a full tank.
Thanks to all - happy motoring!
Hi Guest!
