djwoody
My fuel pump has been oozing gas onto my garage floor so this weekend I decided to replace it.
Removal was pretty straight forward and I discovered the old pump had a slight crack in the glass sediment bowl. Connecting up the new pump went smoothly until I tried to reconnect the fuel lines to the inlet and outlet. This is a simple compression-type connection but I was not able to get either side to seal. I even tried some plumbing teflon tape on the threads to try and get them to seal but no luck.
How do I make these connections leak-proof?
