Leaking Carburettor
Novamonte
Hi,
When replacing a dry and leaking fuel hose on by Tricarb BT7 I noticed that fuel also drips from the brass stud next to where the fuel line is attached to the carburettor (see pic). Does anyone have any ideas as to why it is leaking here (and also why there is an unused connection on the carb).
Many thanks!
Clas
N
Novamonte
Thank you! I also found a reference to that part on Moss' webpage (although it is unavailable). Should I just run the hoses down under the car, and how long should they be? I guess that they should be long enough so as to avoid fuel dripping on the manifold or downpipes...
Patrick67BJ8
Give British Car Specialist a call and see what they have available.
Keith_M
Steve is correct that these are overflow ports. However, a correctly functioning carb shouldn't overflow. If you've got fuel leaking out it's probably because 1) the float is incorrectly adjusted; 2) the float has sunk; or 3) the needle valve is leaking.
steveg
I originally used clear fishtank tubing to the bottom of the chassis rail, but it became brittle from the heat. So replaced both drains with brake line tubing, attached to the carb overflows with short lengths of rubber tubing.
Adding that, on later cars at least, the overflow drain tubes went through a grommeted hole in the heat shield. Looks like your car doesn't have that kind of heat shield, though.
N
Novamonte
Here is an update - I checked the leaking carb and found that the needle valve was quite worn, so I replaced all of them and now everything works fine without dripping from the overflow vents. I added clear oil-resistent tubing to these as per Steve's picture, but was unable to find springs that would fit in them, so I put larger springs on the outside of the line instead which do the same job.
Deleted member 21878
Clas
i was able to find some springs at a local hardware store. i then took a piece of number 12 house wire and cut it to the length of the spring. stripped it to the copper. then i wove it in the spring and after inserting it into the hose, i bent it 90*. the wire holds the spring and the tubing at a right angle.
i did not run mine all the way down under the car. if i decide to do that i will add soft copper tubing to the end of my clear tubes and run them down. Lots of heat down there.
N
Novamonte
Thanks! The springs I was able to find were stainless but not small enough to fit in the tube. But it works well, it keeps the tubing from collapsing. If I find smaller springs I might change this. I also did not run the tubing all the way, just far enough to make sure that gas will not leak onto the downpipes or the manifold.
Clas
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
S Leaking HD6 Rear Carb Austin Healey 10
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
S TR2/3/3A rear main seal is leaking Triumph 13
R TR2/3/3A Leaking O.D. section of Transmission Triumph 43
E Oil leaking from the Tachometer cable Austin Healey 5
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
drooartz Leaking 5-speed drain plug Spridgets 26
S TR2/3/3A and the radiator was leaking. Triumph 7
H TR4/4A Leaking ft hub seals Triumph 5
D BT7 rear wheel leaking Austin Healey 25
B MGB Hif’s Rear leaking gas MG 11
J TR4/4A Head leaking water Triumph 14
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
C TR6 Brake servo leaking Triumph 3
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
R soft plug leaking Austin Healey 45
George Zeck Master Cyl Leaking .... Spridgets 5
M TR2/3/3A O/D brass cap leaking Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
rjc157 Leaking steering box Austin Healey 4
B mysterious leaking of SU HD8 Jaguar 9
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
B Rear Engine Side Cover Leaking Austin Healey 9
D Overdrive Leaking Oil Austin Healey 4
KVH TR4/4A Oil Pressure Banjo Nut is Leaking Triumph 6
H TR2/3/3A Leaking Fuel Pump Sediment Bowl Triumph 5
PatGalvin TR2/3/3A Leaking SUs. Advice badly needed Triumph 15
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Michael Oritt Leaking oil pan Racing 8
T TR6 leaking carb TR6 Triumph 17
TRMark TR4/4A Leaking Drain Tap before I could even get the radiator full Triumph 1
Rob Glasgow Leaking tapered plug on head Austin Healey 8
Scotsman TR2/3/3A leaking front engine plate Triumph 4
bigbadbluetr6 TR6 Carb leaking Triumph 12
M TR2/3/3A Head gasket leaking in two places Triumph 13
Boggsy64 MGB Stormberg leaking like a sieve MG 4
