Lead/Tin 50/50
K
KSIS
I have a small pin hole leak in my over folw tank and would like to rapir it. I spoke to a few people and they recommend the old Lead/Tin 50/50 rather than the modern Tin/Antimony type.
Anyone klnow where I could source it?
dklawson
Why not just the current generation of solder from the home center? A pin hole leak won't be under a lot of pressure or stress. The "regular" plumbing in the hardware section will be suitable for hot water applications under higher pressure than a radiator or overflow tank.
TR3driver
Great Pumpkin - R.I.P
My experience with the lead-free sold at Home Depot (there are actually many different types of lead-free solder with different characteristics) has been that it is much harder to get a good joint with the lead-free stuff, especially on older metal. Of course you need to clean to bare metal either way, but with both acid and rosin core lead/tin solder, that seems to be sufficient. The lead-free stuff seems to require more thorough cleaning followed by washing with solvent, etc. even when used with the special flux that is sold with it. The lead-free solder also requires more heat (which is more apt to cause oxidation that will inhibit the solder sticking) and doesn't "wick" nearly as well as lead/tin solder does.
martx-5
I still see 60/40 solder in the Home Depot type places. That is what Randall refers to as "eutectic"...well, theoreticly 63/37. (I had to look up eutectic solder) :laugh:
dklawson
Thanks for the explanation Randall. I have seen exactly what you describe, particularly that with the "new" solders more heat is required. However, I still have pretty good luck using "No-Korode" flux with the new solders. Resin doesn't seem to work very well and I save the little bit of acid flux I have left for those times I need to solder steel.
71MKIV
My experience with the newer solders lie in the fact that the melt temp is very very close to the flux burn temp.
Once the flux is burnt, you gotta start over.
If you can sneak up to the melt temp and get your soldering done, the newer stuff works quite well.
But if you are in an area where you need to heat quickly in order to solder before someplace else melts, it gets very difficult to get a clean job due to the fact that the flux burns from the amount of heat it takes to bring the temp up in a hurry.
FWIW
Don_R
Not sure (i think 60/40) on the solder but At my friends shop he used
TinTasTic on the radiators before he soldered any leaks. also used a sand blaster to prep the area.
Don
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
S Gas additive, Lead Substitute - BJ8 Austin Healey 9
Rut Lead for bodywork Spridgets 5
D Lead additive Jaguar 12
Sopwith_Camel lead lights Jaguar 6
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
rjc157 TR6 Lead Substitute Triumph 5
S Austin Healey LEAD replacement in gasoline Austin Healey 4
aeronca65t Lead East this weekend [in NJ] Other Cars 0
M ignition coil high tension lead connection Spridgets 10
B TR2/3/3A I'm going to try some lead repair. Can I do this to my doors? Triumph 9
J Lead my gas..? Austin Healey 3
B Lucas lead 'helmet-type' battery cables Austin Healey 5
drambuie looking for a good lead fuel additive Austin Healey 5
tri_carb_healey leaky lead carb Austin Healey 6
JamesWilson Holes- Lead Loading Restoration & Tools 0
K Zinc and Lead Again? Triumph 15
L Valve seats and lead [substitute]. Spridgets 18
B Lead on xj6 series 1 / Chevrolet 350 Jaguar 0
bcbennett Radio antenna lead Triumph 3
Tr4dude How does a paint chip lead to this? Triumph 13
7 neat tool to make your own lead hammer. Restoration & Tools 10
vping MGB Lead Seams - '63 MGB MG 4
JamesWilson Can Aluminum be Lead Loaded? Restoration & Tools 3
prb51 Valve seat recession/ lead substitute Triumph 2
74WannaB Lead work on 74 B MG 3
J TR6 anyone have a lead on a body tub for tr6 Triumph 2
RickB lead additive? Spridgets 9
J TR4/4A Anyone have a lead on a wiper switch for a TR4A? Triumph 8
S Lead or octane boost? Austin Healey 3
T TR6 TR6 died - moving plate earth lead fired Triumph 15
AweMan Soldering Lead and Silver Restoration & Tools 10
G Red Lead Primer Triumph 5
R Lead substitute Restoration & Tools 13
jlaird Todays question, no lead head Spridgets 7
mgbmedic about lead substitutes... MG 16
jaybird Lead additive Spridgets 13
R Lead-Free Cylinder Heads Austin Healey 10
Mark_Gibson Wedge A Good Lead on TR-7's and 8's for Sale Triumph 2
DerekJ #6 Plug lead arcing Austin Healey 4
D no lead cylinder head conversiom Triumph 7
Mark_Gibson Another British Parts and Service Lead Triumph 0
Y Lead Substitute Austin Healey 1
G Lead Head Knock-off Hammer Austin Healey 10
2 Lead Additive Triumph 6
aeronca65t "Lead" Fuel Additives? Restoration & Tools 21
Jim_Gruber Tired of the tin worm,good Spridget body for sale NFI Spridgets 0
donbmw Tin Tin movie Triumph 6
rick_ingram Farina Magnette tin toy MG 6
