Latest '63 Midget Up-date
tony barnhill
Great Pumpkin - R.I.P
Latest '63 Midget Update
Front suspension is in - steering box goes in next & front end is ready to set down on wheels....engine compartment is ready for engine; behind grille is finished & ready to be buttoned up; body is finished except for side trim & bumpers; gas tank is in along with all plumbing.
So, its just the rear end, engine/tranny, windshield, dash & interior to go!
Here are a few photos (just to make grown men cry):
Re: Latest '63 Midget Update
And another...
A last one:
Re: '63 Midget Update
Lookin' good, Tony. You'll wind up a true Spridgeteer yet!
Looks nice. But who shrunk your washer bottle? And... is that plastic hose coming off the fan towards the heater box?
Yep, its plastic but its going away now that Jack has turned me on to Ed's OE style hose which hopefully will arrive shortly...you want it?
& that's the same size washer bottle that was in it before I started the restoration...do I need another size?
I thought the ones that mounted up front were bigger and they didn't switch to the smaller size water bottle until they moved it up by the firewall.
Nope, I've got one of those plastic ones on the midget. Easy to clean but doesn't look right or fit very well.
BTW, if you want a larger bottle that doesn't cost quite as much as the Moss version then look for a place that sells chemistry lab equipment.
Man is that looking great. Now I feel bad about Miss Agatha.
Bugeye58 said:
They're referred to as "Nalgene Bottles".
https://www.nalgene-outdoor.com/store/detail.aspx?ID=59
Jeff
Thanks, guys, I've got the labels to go on a larger bottle....will my cap, etc fit the one referenced?
Photo, zimmy?
Thanks, zimmy....that's the same one in my '74 RWA Midget - its also the small one that's in the holder in my '63....the '63's holder is just much larger.
Tony, you got wheels on the ground and engine and tranny in yet?
Everything's finished in the front - just need to bolt the wheels on up there.....started assembling rear end this afternoon before I had to stop to cut grass....got the bushings pressed into the radius arms - next is installing radius arm & shock brackets & hanging the rear end
Hope to get that finished tomorrow & have her sitting on all 4 wheels Sunday afternoon.
Be sure to put the spacers on the correct side of the radius arm. And when you find out the correct side... let me know. I'm not sure mine are correct.
