later model turn signal in a 67B
19_again
I'd like to have a newer turn signal unit that allows flashing of the high beams, and my year has the high beam switch on the floor. will I be able to just pull the old switch and replace it with one of the newer ones? I know that some years incorporated the horn into the stalk unit, but I just wouldn't hook that up. And while Doc will warn me about getting my foot all tangled up in the steering wheel when I have to use the switch to put on the high beams, I'll take my chances.
Thanks,
Mike
Mike - New replacement turn signal switches for the early MGB have a high beam flash feature. I have one on our 66 MGB, but I use the feature as a single sweep switch for the wipers rather than hi beam flash. Either way, the feature is available. Cheers - Dave
