Andrew Mace said:How new (or newly rebuilt) is that master cylinder? I wonder if it might be failing internally, enough to cause pressure to force fluid back into the reservoir?
NutmegCT said:I removed about 1/4 inch so the fluid level only reached the base of the neck.
TR3driver said:Do you have to pump up either the clutch or the brakes ?
NutmegCT said:However, now that I've done a great job of hijacking TDSkip's original thread, maybe I'd better move this all over to the "Junk parts and cheap fixes" area?
Check your manual, if you have a 'macro' mode. Mine does, but I'd sure never find it without the manual! Turns out you press the 'pan left' button while in picture-taking mode, and an icon of a daisy appears. (My photos are blurry because I used ambient lighting and my hands aren't steady enough.)<div class="ubbcode-block"><div class="ubbcode-header">Quote:]What's the diameter of that rubber gasket? [/QUOTE]Sorry, had to go to work, and tonight will be very busy packing for a trip. Maybe someone else can help out.NutmegCT said:Sorry for the focus (my cam won't get close enough),
startech47 said:If you have air in the braking system it will burp back.
