HighAltitudeTR3
**oops, I said wheel bears. you know what I meant.
I do not think any work has been done to the engine before my work has started (so unless they put a different piston in at the factory, which I can't imagine would have happened) then I would assume they are stock.
Piston/rod come out from the top, they cannot be taken out from the bottom.
Sounds like you need a workshop manual, download the following free PDF to your hard drive, it is big file so be patient ....
https://tecb.eu/onewebmedia/Triumph TR2, TR3, TR3A factory service manual.pdf
M.
Someone worked on that engine or replaced it with a late TR4A engine before you got the car, out of the factory the connecting rod bolts on a TR3 would have lock tab washers installed and I don't see them on the picture you posted.
See item #56 in this Moss catalog page.
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=36459
M.
Well Merlin, I guess I should buy you a beer or something! Looks like I have a CT engine. Now just to quickly go back and recheck everything I've done so far to make sure I'm compliant. Ugh.Someone worked on that engine or replaced it with a late TR4A engine before you got the car, out of the factory the connecting rod bolts on a TR3 would have lock tab washers installed and I don't see them on the picture you posted.
M.
I depends which bolt was used to put the con rod caps on.
Look at item #57 on the link I sent you, they changed at engine number CT34071E.
But with the age of the car and prior mechanic/owners doing whatever, you can't depend on just the engine number for guidance.
At this stage of the game since it would be hard to determine which bolts you have.
I believe the safest approach would be to put the lock tab washers on.
I don't have the two different bolts on hand to do a side by side comparison of length, etc. So you might want to call Moss or the RoadsterFactory tech support guys to verify.
M.
I guess it's possible if the unthreaded shank of the bolt that requires the lock tab washer is longer.Hold the phone! I think I'm catching up, Merlin.
If the wrong bolts are used could the bolt bottom in the rod, but the cap still be loose?
Very true, also the rod bolts would have failed a while back from metal fatigue.If you had a problem with the bolts not pulling the cap down, the insert in your picture would probably be paper thin in the middle sections.
