Could someone please explain the King Pin shimming procedure to me. When I tighten the nut all the way down, my pins no longer turn. Does this mean I have too much or too little shim?
Westfield_XI
add shims until the swivel axle is snug verticaly and turns with slight resistance when the king pin nut is torqued to the proper value. If you put in too much shim then the swivel axle can move verticaly and thats not good. Makes for all kinds of banging sounds.......
