Key Blanks
Dr. Smoke
Member
Does anyone know of a good source of a key blank for the ignition for my 1966 Austin Healey 3000? Only have one key, and I need a spare...
Healey Nut
Clarke Spares .
vette
Try Healey Surgeons, Tacoma Park, Md.
Dr. Smoke
Member
Pete will most likely have an original key for your car, not just an original blank. I've bought from him numerous times, and the last time was just last year. That said, he is not getting any younger and I would not postpone contacting him to see if he has what you want.
I emailed him over a week ago...sadly, no response...
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
mgb4tim "MG" Key Blanks - I'll have a few extra. MG 4
mgb4tim Wedge TR7 Key Blanks - I'll have a few extra. Triumph 0
J Ignition Key Malfunction Austin Healey 6
PAUL161 T-Series MGTF Ignition Key MG 7
J Coach Key (T-Key / Chruch Key / Fool's Key) Revival Restoration & Tools 0
KVH General Tech Oil Pump Woodruff Key Triumph 10
M TR6 Key Codes Triumph 7
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
S TR2/3/3A try start it with the key and it blows the fuse Triumph 7
6 1965 Sprite Ignition Key Spridgets 3
R Woodruff key for DWR camshaft? Austin Healey 2
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
K Correct key head shape. Austin Healey 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
S TR4/4A key cylinders Triumph 6
S TR4/4A Ignition switch key position Triumph 2
TomMull TR2/3/3A Wee coach key Triumph 2
CJD TR2/3/3A Original Style Coach Key? Triumph 24
G Generator - Key Replacement Austin Healey 6
S Open a ingnition key barrel to find the key number. Restoration & Tools 2
S key ID from a barrel? Other British Cars 5
Rut RX7 key fob Spridgets 6
Scotsman TR4/4A Commission Plate interpretation "key" Triumph 3
Got_All_4 TR2/3/3A Ingnition switch key change Triumph 7
5 ignition-trunklatch key Austin Healey 3
W TR6 TR6 Horn only works when key is off Triumph 27
M TR4/4A Trunk/Boot lock key code?? Triumph 4
F Sunbeam/Hillman Key Blank Sunbeam (Rootes) 4
H Spitfire Triumph starts just fine but Ignition is 'Off' and key is in my wife's purse. Triumph 6
S TR2/3/3A small woodruff key Triumph 5
W Bugeye ignition key repalcement Spridgets 2
S TR2/3/3A timing chain cover and woodruff key Triumph 4
D Start Bugeye with KEY only - OR - KEY plus light switch on S or H? Spridgets 4
pkmh BJ8 - Removal of existing Key Washer behind castellated nut Austin Healey 20
J TR2/3/3A Ignition key issue Triumph 4
JPSmit Wiring Key - hand to have Restoration & Tools 1
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
PatGalvin TR5/TR250 TR250 Ignition Key Question Triumph 4
S TR6 TR6 project back together- turn the key and CLICK Triumph 7
M 99 XJ8 How Do You Troubleshoot Key Transponder Module? Jaguar 0
M X-308 99 XJ8 Engine ECU and Chip in Key Jaguar 2
K TR2/3/3A TR3 Dzus Key Fob? Triumph 4
M T16 engine, ecu and two key fobs, or Rover 820 Rover / Land Rover 0
TonyPanchot Spitfire 72 Spit 1500 Key Light Triumph 2
K TR2/3/3A TR3..testing wiring..leaving key on..Petronix? Triumph 3
