Kent Cam
Kent 276 Cam MD duration asp 270° sca 280°
Is for a 1275.
Sorry Jack
yes, 1275 9.5 compression, fully ported head, maniflow intake, modified carbs, LCB, etc.
Thanks,
Patrick
heading back out to the garage, you guys are great!!!!!!!!!
Wonderful search engines on the web, I'm not really so smart.
Thanks, just know that I put in a piper that Vizard had recommeneded in another car and it was so good. Going out to strip and paint, thanks!!!!!
Hehe, wish I had one for a 948, about a stage 2 would be nice, some day maybe. I like the loapey sound.
The 276 is a nice cam good to about 7000 thru the gears and about 6200 to 6500 top gear. It is the required Spec-Sprite cam. Good with stock carbs( needle change needed). Would work great for the engine you discribed. About as much cam as you really want on the street. It will idle ok at about 12 to 1500 rpm. My Spec-Sprite make about 90HP to the back axle on my dyno. Your results may vary.
Jack,
"Stages" don't really mean anything to me, so listing specific statistics/parts is generally more helpful. /ubbthreads/images/graemlins/smile.gif
Understand, and I can not find my reference either.
Stage I = engine clean up, valves, head, 1 1/4 carbs etc.
Stage II = above with street cam, full ballance and lightened flywheel, etc
Stage III = full compontetion version, all the above and more.
Sorry but I can't do better from memory.
