I will try and answer both of the last posts with this one.
First a question, for Searcherman, how did you raise your jets back up? I understood it is a one way trip. Down only.
I have been attempting to read the plugs. Do a drive over varied conditions, I have a 6 mile loop that includes up hill and down and a nice straight away. I stop the engine and declutch and pull over and pull the plugs. Usually 2,3,4,and 5.
Until the last couple times they always seem to be dead white.
Plugs are NGK BR6ES.
I did block off the bypass valves, and I replaced the needles as the ones installed were B1E's if I remember right. When I put the carbs back on, it wouldn't run hardly and when I tried to rev it, it backfired. Never had that happen. Started over looking for vacuum leaks. I noticed the 2nd and 3rd footballs were not located in the dimples of the intake manifold ears. So I loosened them and moved them and retightened. Now it would run and no backfiring. I still seemed to be running lean. I put the old needles back in as they are a smaller diameter. Lets in more fuel. They both run richer but the front 3 cylinders still are only getting to a dark grey while the backs are black and brown.
Put on a vacuum gauge, still under 17, kind bounces just like this one depicted on this website for poor rings.
https://www.therangerstation.com/Magazine/Summer2003/VacuumLeaks.htm
I got a new intake exhaust gasket and while talking with my guru, I sounded like I have probably over tightened the manifold fasteners. I pulled them off and found I have one broken football flange and one cracked one on the front two attachments for the exhaust manifold. Replaced installed the new competition gasket, which is much thicker and has no metal surface, carefully tightened the fasteners evenly working from the middle out. Shimmed the exhaust pipes to relieve some loading they were putting on the exhaust manifold.
Started it up and same vacuum reading. This is with all vacuum ancillaries blocked off. Reading is still under 17 and bounces like before. No change to the carb.
I also checked the output of the fuel pump which I just rebuilt. I did not have a gauge, but it pumps out steady flow and will push against a restricted hose. I would judge it would make a couple psi. I do wonder about the check valve. How long it would hold pressure.
As all of this was to get the car ready to go on vacation, I finally threw in the towel Thursday night at 10:30 and we left for Montana, Friday morning leaving the TR6 in the driveway.
I am contemplating the AFR gauge, I already have the bosses welded to the down pipes. I installed some narrow band AFR's but haven't had much luck getting good readings. They always say rich .8 to .92 when the plugs show white. I am also bidding on a snap on vacuum fuel pressure gauge as the vacuum gauge I have is of dubious quality. When I get back I will start over and figure this out.
