keeping the heat out
John Morralee
It was a hot/hot evening and we ( 5 other healeys ) had been fighting stop/go traffic for the last 30 mins. Keeping the heat out was the subject. One car owner said he had installed baffles around the exhaust pipes where they leave the engine and pass under the unfortunate driver, as I look at my BJ7 with an eye to installing same it does not appear apparent to me that this would be benificial . Has anyone done same or similar?
Dave Russell
Yoda - R.I.P
Hi John,
There is little doubt that the cars get very hot inside. Some folks go to great lengths to improve on the original minimal heat barriers.
There are some very hot parts just on the other side of the firewall & floor. Fixes include additional heat barriers of various materials & constructions. These are applied to the outside, inside, or both of the cockpit surfaces. They all reduce the inside heat, some, remarkably well.
The sources of heat are both radiant & conducted. The baffles you mention could well reduce radient heating.
I hesitate to make a specific recommendation because everyone seems to have their own favorite methods & materials. A search of this website should turn up a lot on the subject.
GregW
Platinum
Hi John,
I’m not sure how the baffles would work any better than the stock heat shields, then again I guess it could be a crafty design. Quite a few have installed heat shielding under the carpet. Some use the aluminum faced bubble wrap and others (myself included) put Dynamat Extreme down. Be warned, Dynamat ain’t particularly cheat. Here is what it looks like.
AUSMHLY
I too used Dynamat Extreme. Over that I replaced the jute with Low-e insulation. Consider the trans tunnel too. The bottom I used Pegasus heat shield and over the top I used Low-e. I also removed the heat shields under the car and glued the Pegasus under them, then reinstalled the heat sheilds.
There are threads on this site all about what members had done. Thanks to those here who help me.
click on attachment for the photo of the Dyamate/low-e inside the car. Other two photos will be a part of this post.
Cheers, Roger
Randy Harris
Yikes, Roger. That's so pretty I think I'd drive the car without carpet!
Randy
judow
Darth Vader - R.I.P
/bcforum/images/%%GRAEMLIN_URL%%/lol.gif /bcforum/images/%%GRAEMLIN_URL%%/lol.gif
I've just 'adjusted' to Agatha and her 'hot' personality. I grin and bear it during the summer and for the rest of the year am glad for the 'heat.'
Good luck with all the solutions.
P.S. My right foot once heated to the nth level becomes numb to the sensation.
suprgnat
GregW said:
Hi John,
... and others (myself included) put Dynamat Extreme down. Be warned, Dynamat ain’t particularly cheat.
Not to resurrect a dead thread, but for a less expensive alternative to Dynamat try B-Quiet Ultimate:
https://www.b-quiet.com/ultimate.html
$129.00 for 50 sq. ft. ($2.58/sq. ft) vs $270.00 (list) for 36 sq. ft. of Dynamat Xtreme ($7.50 sq. ft.).
The specs are virtually identical.
B-Quiet Ultimate:
Acoustic Loss Factor ASTM E756 @ 200 Hz:
0.23 @ +0C (+32F)
0.26 @ +10C (+50F)
0.39 @ +20C (+68F)
0.32 @ +30C (+86F)
0.24 @ +40C (+104F)
Dynamat Xtreme:
Acoustic Loss Factor @ Temperature
(Using ASTM method E756 @ 200 Hz):
0.081 @ +14°F (-10°C)
0.240 @ +32°F (+0°C)
0.257 @ +50°F (+10°C)
0.417 @ +68°F (+20°C)
0.259 @ +86°F (+30°C)
0.194 @ +104°F (+40°C)
0.140 @ +122°F (+50°C)
0.094 @ +140°F (+60°C)
Dynamat is slightly better at lower temps and B-Quiet is slightly better at higher temps, at least in terms of the Acoustic Loss Factor. For all I know, It's just a statistical error and they both source from the same factory!
Installation wise, if "Dynamat" wasn't emblazoned all over their products, you'd never know the difference. I've used both, but only used the Dynamat because I ran out of B-Quiet and could get the Dynamat 4 sq. ft. Wedge Pack for the princely sum of $40.00 ($10.00/sq. ft.!!!) from the local Best Buy.
Paul
suprgnat
Their listed withstand temperature range:
Temperature Range:
-60C to +155C (-76F to +311F)
(cut a pasted from their site)
Dave Russell
Yoda - R.I.P
These products were intended to be sound insulators. Any heat insulation benefit is a by-product, thus not usually specified.
We "could" assume that the heat insulating properties are similar/proportional to the acoustic loss specs. Maybe yes, maybe no.
In the real world, Dynamat Xtreme has proven to be a quite good heat insulator. In my opinion, it's exceptional adhesive qualities allow it to be tightly rolled down over clean surfaces with no fear that water will ever get under it to cause rust. The Dynamat was overpainted body color & nearly invisible.
I've found that two layers provide a lot of heat blocking & take up little space. No doubt there are cheaper ways to go & likely just as good.
Pics attached.
wangdango Keeping the heat out? Austin Healey 11
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
J What's the Secret- Keeping New Aluminun Shut Face Finishers Looking New? Austin Healey 7
M Looking for opinion on keeping original parts for my modified Healey Austin Healey 8
R Keeping Cool in Florida Austin Healey 1
D Keeping Bondo cool - Texas style Spridgets 1
M Generator not keeping up? Triumph 10
K Keeping a Flywheel from rusting.... Triumph 13
T Keeping the throttle linkage shiny Triumph 5
J Electric Fans and Keeping Things Balanced Triumph 3
drambuie KEEPING YOUR HEALEY RUNNING COOL....... Austin Healey 23
E Keeping the rodents at bay Restoration & Tools 5
N Keeping cooool !! Spridgets 24
Newkie MGB keeping mice away from my winter stored MGB MG 11
John_Mc Denial not keeping rust away. Triumph 13
SCguy TR4/4A Keeping your TR4 cool? Triumph 13
kodanja Keeping up with Traffic Triumph 51
ronzet Keeping the brake and fuel lines nice and bright Austin Healey 3
A keeping choke from sliding back in Austin Healey 28
B Keeping doors closed Austin Healey 17
U Keeping Them On The Road Triumph 5
Bret Keeping busy: Cosmetics upgrades. MG 12
B Keeping my top on Austin Healey 6
HealeyPassion Reducing Muffler Heat Austin Healey 2
steveg Heat Shields Austin Healey 17
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
V heat shield Triumph Classifieds 7
EWD TR6 Sound/Heat Mat installation - 74 TR6 Triumph 14
M Heat-related carb issue on BN1 Austin Healey 7
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
AH67 Heat Shield finish 66 Type Jaguar 5
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
K TR2/3/3A Revington alternator heat shield. Triumph 0
60TR3A Is It Safe to Heat My Garage All Winter While I Am In Florida? Austin Healey 34
K TR2/3/3A DIY Alternator heat shield>>> Triumph 2
L 100/ Moss Heat Shield Austin Healey 2
DornTRoriginal TR2/3/3A Heat Shield Issues Triumph 6
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
GTP1960 TR2/3/3A Carb. Heat shield location? Triumph 11
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
T TR2/3/3A Fuel line heat shield Triumph 39
NutmegCT heat valve control cable Other Cars 0
MikeAH100M FYI - Hardie Board for Heat Shields not Recommended Austin Healey 9
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
69mgbgt No cabin heat in my 1997 jaguar xj-6 Jaguar 1
I Spitfire If you can't stand the heat.... Triumph 7
J Side exhaust heat shield Austin Healey 23
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
