Keeping a Flywheel from rusting....
karls59tr
circumstances lead to leaving a TR4 trans with flywheel in an unheated garage for the winter. What can I do to keep the face of the flywheel from getting rusty?....spray?..Grease???
TR3driver
Great Pumpkin - R.I.P
Most likely it won't need anything at all as long as it's out of the rain. I've got a lot of parts, including flywheels, that were stored for many years in an unheated garage, with no damage.
However, I've been experimenting with a product from the folks who make PB Blaster, called "Blaster Corrosion Stop". It's basically just a spray grease with a solvent carrier that evaporates; leaving behind a fairly thick layer of grease. But it is readily available around here (Walmart, Home Depot, etc), inexpensive, and so far seems to work very well even on parts that are stored outdoors.
https://www.blastercorporation.com/Corrosion_Stop.html
I've tried other products from various sources, but so far the Blaster product seems to be winning. YMMV
DougF
Another good rust inhibitor is LPS 3. It sets up as a soft waxy coating.
TomMull
Personally, I don't like putting grease on parts like flywheels and brake discs because you've got to get all that grease off. What about a large ziplock with a couple of desiccant packs?
I also have several flywheels that have been crudely stored for many years with no rust at all (perhaps they had a little oiling from the rear main?).
Tom
FordFiesta
Vegetable oil, and in a plastic bag?
Darn-near any kinda greasy-stuff will do, as all you're trying to do is separate the metal from the oxygen source.
hondo402000
the only time I have had an issue with cast iron rusting is in the spring when like my planer deck is very cold and spring comes with a very humid day and the cold cast iron will have moisture condense on it, On the fly wheel I would think about spraying a primer on the surface where the clutch goes and if you ever use it just sand the primer off. In fact I dont see why you couldnt prime the whole thing
Hondo
Don_R
I break out my trusty can of Cosmoline when I need it...
FordFiesta
Or just keep the transmission indoors in the tub of the guest bath...which I used to do before meeting my wife.
CJD
+ 1
It's what they use on aircraft that sit out in the weather...
Brinkerhoff
I'd just spray it with a light coat of lacquer in a spray bomb. The just wipe the paint off with thinner when you get ready to use.
TR3driver
So how do you get the right kind? I bought a can that says "Cosmoline" but what comes out is more like WD-40.
Don_R
I work in an ordinance foundry....make mortar shells for the military....Grabbed a couple of cans of milspec stuff...
PatGalvin
Why not go to your local marine supply and purchase some anti-corrosion spray (like Quicksilver Corrosion Guard - check EBay too)? It's what you spray on your boat engine prior to putting it away for the winter. I'm sure it can be removed with Brake Cleaner or mineral spirits in the spring. Cheap and easy.
wangdango Keeping the heat out? Austin Healey 11
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
J What's the Secret- Keeping New Aluminun Shut Face Finishers Looking New? Austin Healey 7
M Looking for opinion on keeping original parts for my modified Healey Austin Healey 8
R Keeping Cool in Florida Austin Healey 1
D Keeping Bondo cool - Texas style Spridgets 1
M Generator not keeping up? Triumph 10
T Keeping the throttle linkage shiny Triumph 5
J Electric Fans and Keeping Things Balanced Triumph 3
drambuie KEEPING YOUR HEALEY RUNNING COOL....... Austin Healey 23
E Keeping the rodents at bay Restoration & Tools 5
N Keeping cooool !! Spridgets 24
Newkie MGB keeping mice away from my winter stored MGB MG 11
John_Mc Denial not keeping rust away. Triumph 13
SCguy TR4/4A Keeping your TR4 cool? Triumph 13
J keeping the heat out Austin Healey 10
kodanja Keeping up with Traffic Triumph 51
ronzet Keeping the brake and fuel lines nice and bright Austin Healey 3
A keeping choke from sliding back in Austin Healey 28
B Keeping doors closed Austin Healey 17
U Keeping Them On The Road Triumph 5
Bret Keeping busy: Cosmetics upgrades. MG 12
B Keeping my top on Austin Healey 6
Y MGB Flywheel saga continues.... MG 24
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
Y MGB Flywheel resurface? MG 2
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
Michael Oritt 100 Flywheel Weight Austin Healey 16
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
WHT Denis Welch CENG635SO Flywheel Austin Healey 0
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
J BJ8 flywheel take some pounds off Austin Healey 17
roscoe Flywheel orientation question Austin Healey 3
R TR6 Pilot bushing clearance and Fidanza flywheel Triumph 0
AUSMHLY Shifting into 2nd, problem because of the Flywheel? Austin Healey 21
M TR2/3/3A What Flywheel is this? Triumph 3
J TR2/3/3A Flywheel-Crank Dowel Alignment Triumph 6
R Wanted BJ8 FlyWheel Austin Healey Classifieds 6
M TR2/3/3A Starter and Flywheel Combinations Triumph 2
Rut Crank/flywheel dowels Spridgets 3
JimLaney Flywheel Pitting Spridgets 4
S TR2/3/3A Alloy flywheel Triumph 13
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
TRopic6 For Sale Flywheel for TR250/'69 TR6 Triumph Classifieds 0
drooartz ID a 1275 flywheel Spridgets 2
D TR4/4A flywheel bolts maybe too long Triumph 15
trotti Flywheel removal Austin Healey 4
drooartz Looking for a 1275 flywheel Spridgets 17
A 1955 100/4 Flywheel Info Austin Healey 4
