TR6 Keep or Lose the Spare?
Martin Secrest
Just curious. I run my TR6 mostly around town and have never actually had a flat tire in 20 years. Thinking about taking the spare tire out of the trunk to save weight, but I wonder if I would wish I had it in the car if I were rear-ended in an accident. What's our collective wisdom on this, if we have such wisdom?
I have a space saver spare in my TR6. It’s from a Accura. It has the identical bolt pattern as the TR6. It weighs less and takes up less room. Got it in a salvage yard for $20.
Yeah, a more modern space saver is the way to go I think. At least a little more piece of mind...and you still save a ton of space.
Cheers
Tush
There are lots of space savers with the correct bolt pattern, you also have to take into account the offset. Mine, from a Honda as well, I think Saab from the 90s will fit too, would not clear the front discs, except I already have a small spacer on for clearance with my wider wheels.
I think you are correct... my space saver fits fine on the rear but needs a spacer up front. If I happen to get a flat in the front I will move one from the rear to the front then mount the space saver on the rear to get me home.
I keep some fix-a-flat and an small air pump in the trunk (boot). Used it once in 20 years to make it home from a nail bite. Wire wheels here, so maintaining a reliable spare in the trunk can easily be forgotten for years and not good when needed.
You're tempting the Law of Innate Perversity of Everyday Life. It holds, in part, that if you have a spare, you'll never need it and it will seem like a waste. But the one day you leave home without it, you'll tear up a tire by running over a dead porcupine. You should realize that the spare is the thing that has prevented you from getting flats these last many years.
What does a full size spare weigh approximately? 50#?
I’m guessing that’s a pretty good approximate. Tire is about 20-23 lbs plus steel wheel should be close to 40- 50 lbs.
All good words from guys that have been around the block. A word I bought a snow shovel before winter a few years ago and have only used it maybe three time ( Nevada). As for the spare I have 16 inch wheels on my TR 6 and as not to damage a wheel I could not replace I have five and with non direction tread can go either side of the car. I rotate all five ounce a year. And you right a lot of money just to go flat and or rot un used. any call is right. Madflyer
I was wondering too, so I got out the scale. Full size TR6 steel spare (w/old Michelin Redline) is 40lbs, and the '97 Honda Accord space saver spare is 20. Bada boom.
So, did you decided to put the space saver tire in your TR6?
I did. The Honda tire fits well on the rear, but rubs on the front, so if I get a front flat, I'll have to swap two tires. But I'll be OK, lol. And there's a lot more room in the boot now, that's for sure.
Yes, you are correct about the tire rubbing in the front. You can buy a wheel spacer for the front if you want. Like you, I will just swap two tires if I get a flat in the front. The additional room in the boot is an added plus.
I just removed the spacers that hold the spare cover up higher on my 250 since I have the space saver. Just drilled out the rivets. I then put some felt on the bottom of the cover so it won't scratch the paint. Had something I wanted to fit in the trunk and it didn't fit. Now it does, I can put the risers back on for originality if needed.
