David_Doan
I've seen pics of these air filters on HS2's but could not find anyone that sells the stub stacks to make it work. So, tonight after work I made my 1st prototypes out of 5/8" particle board. I don't have a 3.5" hole saw so I used a really cheap adjustable single blade hole saw. I cut both slightly too big, then mounted them in my redneck-lathe to clean them up and sand them smooth. Then I used a 1.25" hole saw to cut the center hole. I'm going to give them a few coats of sandable primer and paint them with engine paint to seal them up. They would probably perform slightly better with a radius on the center hole, but the breather hole is too close to do that with particle board. If these work well, I think I will eventually make them out of plastic. For now, it is a basically free way to get rid of the ugly stock air cleaners.
